valve seal install F*&K up??? (PICS)
i have stock guides and stock valves on my 241 heads. i have the comp cams valve seals #511... how hard do you have to tap these things to get them to completely seat? what size of socket do i use? im using a 3/8 deep socket to get them on and they seem to take alot of force when tapping to get them to seat completely. also i damaged some of the little springs that are on the seals, does that matter...
im pretty frustrated at the moment any help would be much appreciated.
![](http://img265.imageshack.us/img265/6567/20111017163210648.jpg)
Uploaded with ImageShack.us
![](http://img853.imageshack.us/img853/1744/20111017163156718.jpg)
![](http://img62.imageshack.us/img62/4509/20111017163149351.jpg)
If you use the correct size socket, and put a rag on top of the socket, you should just be able to push it down. You shouldnt need to "Tap" anything. I have always put a small ammount of oil on the inside of the seal to help it slide on. They fit tight enough that they wont come back off even with some lube on them.
Ive installed dozens of sets of these and it does take quite a bit of pressure when pushing them on, but they will go.
They don't need much to seat them. I used a socket and small hammer and lightly tapped on them. You'll know when they are seated based on the change in sound when striking with a hammer. As soon as they are seated, it's more of a thud sound instead of pinging.
No wonder your other post was so confusing. What wasn't caught was the fact that those aren't seats at all! Those are the ti retainers that go on TOP of the springs. You need to post a pic of all the spring parts you have contained in your kit.
i had to install a set of seals similar to you show there. i removed the springs from the seal,gently tapped them on and then reinstalled springs. everything worked out ok.
You're not supposed to put them on as far down as they can go ,,,,,,,according to the book You install a new valve stem seal over the valve stem and press it down over the guide to the specified depth using hand pressure . Don't force the valve seal against the top of the guide . Don't You have a repair manual ?
LS1Tech Premium Sponsor
Good call! That tool will pay for itself numerous times over its life!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Neh, those are definitely seats, just made for aftermarket (larger diameter) guides.
__________________
My spring locators are the wrong size as well. I valve seals were bad and I changed them. The motor started smoking again. Checked the seals and they were pulled off of the guides. Could the locators cause this problem?
