Lost oil, now its knocking
Old Nov 5, 2011 | 02:01 PM
SportGoldSS's Avatar
Default Lost oil, now its knocking
Started a street tune on my car yesterday and once we got it about where it needed to be I took the tuner home and headed to work. On my way to work I heard a knock, and it got louder. I pulled into work and checked my oil... It was very low. I had just checked the oil a couple days ago and it was fine and I hadnt driven it since then. I called a friend and he brought me some oil, it took two quarts to fill it back up.
About the knock. I cant hear it at idle and it is most noticable at around 2000 rpms under a load. Sounds like its comming from the valver cover and it sounds almost hollow, like somethings hitting the valve cover.
Old Nov 5, 2011 | 03:17 PM
3rdCoastPowerSports's Avatar
i would take the valve cover off and have a look... it is not going to get any better by ignoring it or hoping it will go away,,, might be something you can easily fix now but in a few more days it might turn catistrophic
Old Nov 5, 2011 | 03:24 PM
CHADsterss's Avatar
Check your spark plugs and make sure they're tight (I had a similar problem and a loose plug was causing it) and check for an exhaust leak. I would do those before pulling the valve cover.
Old Nov 5, 2011 | 03:28 PM
that right there is good advice
Old Nov 5, 2011 | 04:23 PM
Im prretty sure its not an exhaust leak but I will check spark plugs for sure.
Old Nov 5, 2011 | 04:29 PM
lemons12's Avatar
It takes 5 mins to pull a cover.
Low oil will kill a motor quick.. ls1s are notorious for it. Check oil 2-3 times a week for a dd.. Every time you drive for a weekend/track car.
Old Nov 5, 2011 | 04:38 PM
that must be nice, take a while on the vette's
Old Nov 5, 2011 | 04:50 PM
lemons12's Avatar
Well it also doesn't hurt I have coils relocated. Haha
 Michael S. Palmer
Old Nov 5, 2011 | 04:53 PM
Guess ill pull a cover tomorrow and check it out. It was down two quarts. Would that be enough to do catastrophic damage.
Old Nov 5, 2011 | 04:56 PM
lemons12's Avatar
Absolutely.
I was less than 1 quart low and spun a bearing.. Granted I was close to 6400rpms, but It still didnt help.
Low oil kills these motors extremely quick.
Old Nov 5, 2011 | 08:02 PM
Cooldude5231's Avatar
were you driving it hard when you noticed the knocking?
Old Nov 5, 2011 | 08:57 PM
No I was not, it was after driving it hard.
Old Nov 5, 2011 | 09:01 PM
lemons12's Avatar
My guess Is It is worse than you think.. Could be a lifter... Maybe even a spring.. Bent push rod. Any of those will show when you pull the cover.
How is the idle? Where is your oil pressure now?
Old Nov 6, 2011 | 12:31 AM
idle is still choppy as **** due to the MS4 but oil pressure is normal. Springs are double .650 lift springs, pushrods are the hardened ones texas speed gives with the package.
Old Nov 6, 2011 | 12:50 AM
lemons12's Avatar
My money is you have a rod knocking. Hope I'm wrong.
Old Nov 6, 2011 | 02:16 AM
Wouldnt a rod knock at idle?
Old Nov 6, 2011 | 02:52 AM
lemons12's Avatar
It should.. You should also hear a litter, push rod, or spring at idle as well however.
Take a broom handle or piece of wood and stick it where you think the noise is coming from etc..
Old Nov 6, 2011 | 11:19 PM
98silvermaro's Avatar
if it was rod knock you would hear it at idle for sure... been there, done that... my bet is that it is a lifter
Old Nov 7, 2011 | 02:40 AM
Would a bad lifter hurt my cam?
Old Nov 7, 2011 | 04:21 AM
Ironembraced's Avatar
cut the oil filter in half and cross your fingers.
