Cam install shopping list.. Is this everything I need?
Old 03-12-2004, 02:39 AM
Z28Venom's Avatar
Post Cam install shopping list.. Is this everything I need?
I'm ready for the install.. My entire exhaust is finally here, and now I'm finally ready to buy everything else for my Cam install.
What I already have in my possession:
TR230
TR 7.4 Hardened Pushrods
COMP CAM Beehive 918's
What I plan to buy from TSP tomorrow!
COMP CAM Titanium Retainers
Rollmaster Double Timing Chain (not heat treated) whatever that means
Ported LS6 Oil Pump
New Valve Seals
Gasket Kit w/bolt
Am I leaving anything out. I'd like to do this once, and do it right the first time.
Thanks for any replies
Old 03-12-2004, 02:58 AM
SSactionLs1's Avatar
yea all looks good... Just make sure you have all the stupid stuff like locktite and oil etc. I would advise you do your ASP pulley while your at it. Good luck bro, cams are fun.
Old 03-12-2004, 03:26 AM
Z28Venom's Avatar
What is the locktite for?
And I can't really afford $200 for the ASP right now either.
Old 03-12-2004, 04:17 AM
the locktite is needed for the timing gear bolts/cam bolts etc. Dont forget dexcool/ oil/ filter/ any tools you need... I know i spent about 200 bucks at kragen on misc stuff to do the job correctly. Oh and gloves will be your best friend.
Old 03-12-2004, 06:24 AM
2002ScottOnyxSS's Avatar
http://www.ls1howto.com/index.php?article=23
Great writeup....as well as a good list of tools...
Old 03-12-2004, 06:15 PM
JDPZ28's Avatar
If it's your first time, lots of patience,beer,bandaids, and a full weekend.
Oh yeah a lift really helps out too
Old 03-12-2004, 06:33 PM
DaleMX's Avatar
Good Gear Pullers, valve spring removal tool, pen magnets or steel rod in case your lifters wont stay up, Big *** breaker bar and impact socket for the pulley, Good torque wrench, long bolt to get the pulley started, extra car for trips to the auto store.
Old 03-13-2004, 01:58 AM
IrateTA's Avatar
1. www.ls1howto.com - best writeup I've ever seen.
2. Longer crank bolt
3. 3-arm puller
4. antisieze
5. spark plug compressor fitting
6. paper towels for the coolant that will soon be on the floor
7. big ***** breaker bar/250 ft-lb torque wrench
- just a few I can come up with having the install still fresh in my head
