what year lq4 for 99 camaro ss swap
Old 11-18-2011, 02:04 PM
supershift67's Avatar
Default what year lq4 for 99 camaro ss swap
I would like to install an lq4 into my camaro but I was not sure what year engine I needed and do I have to worry about reluctor wheel tooth count or anything else for that matter. Will 2001 and up engines work in a 99 ?? thanks
Old 11-27-2011, 08:12 PM
brettw1320's Avatar
from my understanding any 2000-2003 motor
Old 11-29-2011, 05:54 AM
Captain Double Post
BOBS99SS's Avatar
im putting a lq4 in my 99 ss this winter, i sure hope it will work lol,
Old 11-29-2011, 08:27 AM
dodson55's Avatar
any 01-06 will work try to get a late 04-06 if you can thay have ls2 rods and coated pistons
Old 11-29-2011, 08:44 AM
black00ssFL's Avatar
This. Lq4's were made up to 2007 (mine is an '07 from a Hummer H2). '04-up had the better rods and floating pistons. ALL lq4's have 24x reluctor wheel.
Old 12-10-2011, 09:09 AM
71 chevy's Avatar
does anyone know if the 04 -07 rod works on the 00-03 crank with no modifications. are the big ends the same size and do they use the same bearing?
Old 12-10-2011, 09:41 AM
dodson55's Avatar
Yes they will work but a 99-00 crank is longer and will not work in a fbody
Old 12-10-2011, 11:48 AM
I ended up buying an 05 lq4 for it. thanks for the help. I may be switching the heads to ls3 heads also since I already have them.
Quick Reply: what year lq4 for 99 camaro ss swap
