LQ4, ported 241 heads, TR224/230 111. Head milling questions.
First i was wondering if there is a good way to find out if a set of heads have been milled? I have a set of ported 241's with 2.02/1.60 valves but don't know if they have been milled.
Second, how much should i mill them? I am guessing with the dished piston ptv clearance is less of an issue but i don't know for sure. Also, how much can I mill them before I run into intake alignment problems? I already have a set of TR hardened pushrods, 7.400 I think is the length, im guessing if I mill the heads those won't work?
Thanks!
Thanks!
Thanks!
Thanks!
Thanks. Have any idea what measurement I should get when I go from valve cover rail to the head surface? Yeah, I was guessing I would have to order some new pushrods.
