Installed Valve Stem Height
Old Dec 8, 2011 | 05:19 PM
N20neenee's Avatar
Default Installed Valve Stem Height
Gents
I got my 243s at the machine shop getting my heads milled and valve job and the machinist has asked me to find out the installed Valve stem height. From what he found in the books was my exhaust valves are abit too tall and to ensure that the non-adjustable stock rockers have the correct valve lash he may need to deck the exhaust valve stems.
This is not the same as installed valve-spring height
Does any one have any info on the correct exhaust valve stem height?
thanks
Old Dec 8, 2011 | 05:28 PM
KCS's Avatar
KCS
Moderator
If I remember correctly, it's right around 2.00". If you're using a larger lift cam, it doesn't really hurt to have the stem height a little higher.
Old Dec 8, 2011 | 10:44 PM
N20neenee's Avatar
Is 2.00 for the exhaust or the intake? My intake stem height appear to be spot on, so that is why IM verifying the exhaust side.
I would think you would want your stem heights the same height thus the pushrods are cut the same length.
Old Dec 9, 2011 | 06:14 AM
KCS's Avatar
KCS
Moderator
Yes, 2.0" on both intake and exhaust.
Old Dec 9, 2011 | 09:58 AM
vettenuts's Avatar
Correct me if I am wrong, but aren't the stems case hardened which means if he grinds the stems he will break through the case hardening and you will have very accelerated valve stem wear.
Old Dec 10, 2012 | 10:12 AM
MikesPerformance's Avatar
Restricted User
Default Stem Height for Trick Flow 215CNC
Just FYI...
Rebuilding a set of Trick Flow 215CNC heads, and the pad-to-stem tip height was all over the place prior to starting the valve job. Called Trick Flow and they gave me a range of 2.035" to 2.045" for pad-to-stem tip. Obviously the pushrod needs to be figured to get the right strike-point for rocker to stem, and in this case we found a 7.525" pushrod give a nice setup.
Also, for you machinist doing valve jobs... the top-cut angle for these heads is 37 degrees, not 35. We coudn't find a cutter for this from either Goodson or Winona Van Norman, so had to go back to the trusty stone grinder. If anyone has a source for a good 60-45-37 CBN cutter (other than having one made custom), please advise. Thanks!
Mike's Performance
Old Dec 11, 2012 | 01:38 PM
KCS's Avatar
KCS
Moderator
The hardening is roughly .030" deep IIRC, so you can grind off a little to get a flat tip.
Originally Posted by MikesPerformance
Just FYI...
Mike's Performance
Try Newen. I've used a Newen cutter with the 37-45-60 before but I can't remember the PN.
Old Dec 11, 2012 | 02:37 PM
Ferocity02's Avatar
How much taller are the exhaust valves than the intakes? I just put together some 799 heads and the exhaust valves sat a bit lower than the intake valves.
