Will this cam require flycutting?
Old Dec 11, 2011 | 02:04 AM
TurbopigB4C's Avatar
Default Will this cam require flycutting?
Will a 243/247 .624/.624 110+2 LSA camshaft require me to flycut when using 65cc 317 heads .054 head gasket thickness with stock valves?
Old Dec 11, 2011 | 09:33 AM
dodson55's Avatar
most likely yes with the heads milled that much what engine is it a ls1 or lq9 i would almost bet it will have to be if its a lq4 you might get lucky and not have to best thing to do is check the ptv clearance then you will no for sure
Old Dec 11, 2011 | 11:42 AM
Its Ls1. What about a 236/242 .615/.624 on a 111+2? If I had the heads milled only .040" instead of .050" to make them 67cc closer to stock ls1 heads would the more extreme cam fit? Its close to a Trex but using the LSL lobes.
Old Dec 11, 2011 | 12:19 PM
Its an auto transmission not a manual also. I know autos can be a little closer on PTV than manual transmissions.
Old Dec 11, 2011 | 12:51 PM
dodson55's Avatar
the cc of the heads has nothing to do with the ptv its how much you mill them a set of 317 milled 40 will have the same ptv as a set of 243 milled the same the second cam you have listed should be fine if you dont mill the heads if you mill them i would check the ptv just to be safe
Old Dec 11, 2011 | 01:06 PM
Would a set of unmilled 243 heads work for the first cam?
Old Dec 11, 2011 | 03:37 PM
dodson55's Avatar
it mite but there would be no way of knowing without checking no longer then it takes to check i wouldnt chance it, why are you set on that big of a cam running stock casting heads you could get more power from a smaller cam and it drive much better
Old Dec 11, 2011 | 04:27 PM
Just looking at the majority of fastest cam only people most have a Trex so I was trying to do something similar and try the new lsl lobes. My car is not a driver just a toy that I drive to the track. I already have a 4500 stall and 4.56 gears which match that size of a cam.
