GM Rocker Arm Material
If you want to know the actual temper you can do a hardness test and derive the tensile strength to give you a better idea. and if you cant find it on google sent it to a material lab, pay 200 bucks and get a spectum analysis of the rocker make up and they can tell you.
OEM rocker arms with the Comp Cams Trunnion/Bearing Upgrade Kit seem to be pretty bullet-proof.
Florida.......Scorpion/Crane????
You cant beat a set of stock rockers with a trunion upgrade in most cases! As we all know the stockers are a fairly good design.
and check this out for a start on an FEA. www.rpi.edu/~des/Rocker_Report.pdf
PS
I can help you design these if you are looking to really make a set...i to have resources. Engineering, CAD/CAM, machining, and lots of fab vendors on a speed dial.
no pushrods were bent, but when the rockers broke, they were pushing down on the retainer part of the valvespring hardware, this may have save the pushrods from bending.
the springs i WAS using were rated at 505lbs springs pressure...ive since then downgraded to some pac-1518 springs and havent had a problem in just over 100 miles since the install.
