Hmmm....Patriot Performance
i was at the SBSO. PP did have a good showing...for using "race style heads". but you must remember, non of MTI's, GTP's,TEA's, AS's fastest H/C cars were there. i think PP will not get the respect until it sets records...at least not from me. What is the price diff between the "off the shelf" and and the TSP hand tweaked heads?
I hate dyno's,if it was not needed for tune I would never use one.My trans died on the dyno and I am waiting on a few more parts to hold the new power.My car has been down since Thanksgiving and I can't wait for that TRUE test,the 1/4 mile.
2) I don't really care what you think the facts are, it is clear that the aren't all the facts.
3) I don't care whether you think PP heads suck, and I don't care whether they really do.
4) I don't see any questions in your post.
5) get a life
You are kidding right? You don't believe you are a troll??? OK, I'll assume you don't even know you are a troll. For starters, you post a select group of data designed to prove your point, ignoring any data that might contradict your point. It is clear from your prior posts that you had your mind made up before this post. Next, you jump on someone else's thread with negative, contrived "results", rather that starting a thread with your rant. Next, your condescending comment following the "results". Further ... well, if you don't get it, I doubt I can convince you.
Son, I've got more knowledge that you are ever likely to get. If you think I am a troll, you don't even know the definition. What question? You didn't ask a question. You just posted carefully culled data to prove a point.
1) The hell it doesn't. It is not the numbers, per se, that make the post trollish. It is the whole post, including the carefull selection of "numbers" that prove your point.
5) get a life
i was at the SBSO. PP did have a good showing...for using "race style heads". but you must remember, non of MTI's, GTP's,TEA's, AS's fastest H/C cars were there. i think PP will not get the respect until it sets records...at least not from me.I'm sure that at any point and time,if anyone wants to match race,tell them call out Trevor,Jason or Lynda.Along as it is the same weight,H/C car on the same track,with the same rules.
I personally hand worked all 3 cars heads.Don't try and take anything away from how well their cars run.I guess everyone forgot the thunder shootout.If you look back at the southern shootout and the sbso,there was only a handful of cars that ran 10's,5 to be exact.Three of these cars have Patriot heads on them.
Shawn
Its the difference that matters. Also dynos are TUNING TOOLS ONLY!
I'd rather have a 10 second HCI car that dynos 420RWHP than a car that runs 11.90@118mph with 450RWHP
by the way terry, i am sure the other racers didnt have their heads pulled aside by their porter to get "personally hand worked".
There were plenty of competitors at the Southern Shootout running a variety of cylinder heads such as Absolute Speed, GTP, etc., and I doubt that Patriot Performance were the only set of cylinder heads being run at the Spring Break Shootout. Dyno numbers make me smile because my auto has never been a dyno queen, but it is setup to run at the track. You should look at the change in power as a percentage, not a straight number. Gaining 30 RWHP when you're making 430 RWHP isn't as impressive as gaining 30 RWHP when you're making 300 RWHP. I put down 430 RWHP unlocked and ran 10's in mediocre weather.
Trevor
Texas Speed & Performance
and now ARE admits the mistakes and even lost they're sponsorship but I think they are really gaining ground now. Anyway, I was wrong then, and you are wrong now.And this is for everyone: THESE ARE DIFFERENT DYNO's, DIFFERENT cams, DIFFERENT tuners/tuning, DIFFERENT trannys/clutches/flywheels/converters, DIFF....I can go on ALLLLL day. But you guys know that stuff right? Thats why your much praised Raughammer went 10.6 with LESS than 400rw? Right? DYNO's are for **** and EVERY shop has good and bad cars. I could put PP 5.3's and a 228+ cam and dyno 39x, then re-tune, switch headers/catback, etc. and re dyno 430+. This is THE stupidest argument I've ever seen on this site.
what is the difference between a set of hand finished patriots, tea's "hand finished to competition level," or absolute speeds since they are all hand finished??? (besides price . . .)
its not like these are heads you cant buy from a sponsor, they are heads the were specially setup for these cars that the average person cant get, so why are you whining about them???
what other cars have run the times that the 3 cars at the SBSO? i am not whining, just questioning why was this event so sponser oriented. i see in your sig that you have PP 5.3s. what times have you run and what kinda power have you put down?
i put down 405 hp and 392 ftlbs through the flowcrapper muffler. 414 hp and 400.4 ftlbs @ 5600 rpms with the caps open (dyno computer crapped out at 5600 and wouldnt work for the rest of the day, based on the previous plots it would have been in the low 420's hp and 400 ftlbs.)
et's are hindered by the stock rear and gears, but i turned 12.02 @ 120.3 on a 2.04 60' (weight of 3450 and DA of +400-500 ft). this was with my 224 cam (dynoed 390 hp and 380 ftlbs at that time). with the new cam and since i have been tuned now im shooting for 122-123 mph next time out
