bigest streetable cam
Not that you couldn't go buy a ms4 or trex and have somebody put a good tune on it but it just seams like there is alot more potential with medium sized cams for street cars imo
i've got 226/226 585 112lsa w/stage2 ls6's,fast90/90 and fullt bolt on,3:73
both m6 cars, and though i ever regret not gettin some big *** cam, powercurve of my car is so much better
But yes, you can drive them on the street!!
All depends on what you want. Big cam cars are just as fast on the street as the track, just depends on if you have the ***** to go the distance required.
My old Ms4 car was a 100% daily driver and every other H/C street car I ran got raped.
With that said... Something around a 228R (or similar) works great. That cam will net you mid 11s in a full weight car with the right combo, sound good, still retain decent mpg, easy to tune, doesn't require 6500+RPMs, 410s 4400 converter FAST etc etc is not mandatory to make a good combo.
Drove and idled perfect.. Shifted around 6200.. Ran ls6 intake/373s/full exhaust/etc..
Advanced Induction.
410s
26" tire
LTs Xpipe 1 chambers before axle
Ported 90/90 setup (FAST 92 came out months after I bought it, this has been a while)
3200ish RW
It ran 7.2s@97mph mid 1.6 60' (stock suspension spinning its *** off).. No tune for the heads 2000+DA.
It was running 7.5s before putting heads on/taking weight out cutting mid 1.5s dead hooking. Added the heads (no retune) and took weight out and cut a .1 slower 60' but picked up .3 spinning my *** off. Car easily had 6.XX@98+ in it with some suspension and a tune the way it sat.. Few more mods (chrs1313/1 7/8 headers/EWP blah blah blah) and 6.5-6.6s@100+mph would be easily attainable. And still drive the car every single day.
One of my best friends ran the f13 in his car.. Was a strong car for another budget setup. Amazing mid range with the 5.3 2.5 heads but lacked top end compared to my car.. I also had quite a bit more down low compared to his 373s/3600 converter setup.
https://ls1tech.com/forums/dynamomet...o-numbers.html
I have this custom cam I had done, Makes 440+ on stock heads. Drives just as good as the streetsweeper I had before, the never surges or bucks. Makes more power then trex, that made the most power. And drove bad, surges and bucks and low rpms.
I wish mods would just lock these kind of threads....
Yeah but I could live with "what mods do I need to make my rough starting no idling surging noisy valvetrain spring eating pushing through the brakes cam streetable" because at least I would know then they at least searched "Donkey Dick cam" first...
very true
