Pulling the trigger on heads, questions inside.
Old Jan 12, 2012 | 05:02 PM
01SOMZ28's Avatar
Default Pulling the trigger on heads, questions inside.
I've been looking at the PRC Stage 2.5 5.3 and the PRC Stage 2.5 LS6 heads. Is there much of a difference between the two?
Also, i'm wanting a 64cc or 62cc chamber (maybe smaller if i can get away with it) to bump the compression. Doing so will mean i'll need to change my pushrod length and possibly check PTV?
Old Jan 12, 2012 | 05:28 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Depends a lot on the camshaft your running. Dont worry though, give us a call with what your specs are & we will mill & setup the heads to your specs!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jan 12, 2012 | 05:31 PM
02ws.sik's Avatar
well from what i have seen the 2.5 5.3 heads are better in the lower range. the 2.5 ls6 heads are better up high and mid range. I got 215 prc heads so i get the best of everything lol and a ms3 thanks texas speed.
Old Jan 12, 2012 | 06:26 PM
01SOMZ28's Avatar
Will do!
My cam is 228/235 .614/.621 111+2 It was spec'd for nitrous, made 381/365 but runs strong. I think some nice flowing heads will help this cam out quite a bit.
Old Jan 12, 2012 | 09:40 PM
MJs1FastSS's Avatar
i have the 5.3's with a ms3 for my z28 and pretty happy with that set up just under 450 rw
Old Jan 12, 2012 | 09:44 PM
MrElectric03's Avatar
I ran the 5.3s on my motor with a cam similar to the tsunami and a FAST ad made 475 rwhp and 435 rwtq. Ive often wondered what some AFRs would have done but the numbers I got were awesome for the price of those heads.
Old Jan 12, 2012 | 09:46 PM
wildcamaro's Avatar
As far as cash goes it looks like Texas speeds are the best bang for buck heads
Old Jan 13, 2012 | 05:17 PM
JPH's Avatar
JPH
I am sure the TSP guys can set you up with what you need.
Old Jan 18, 2012 | 04:16 PM
01SOMZ28's Avatar
Should my 7.425 pushrods work with the PRC 2.5 5.3 head with a 62-63 chamber? maybe 7.400? Picking up a lightly used pair from a friend.
Old Jan 18, 2012 | 04:38 PM
Sales2@Texas-speed's Avatar
If I had to GUESS, 7.400", but until you use the tool and measure it is just a guess.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 18, 2012 | 04:55 PM
01SOMZ28's Avatar
Yea that's what I was thinking but I'm just going to order the tool to measure, they're cheap and it'd be worth it.
