head notch and gasket questions
For nitrous, I'd definitely have them welded and probably use studs rather than bolts.
In general, If you use MLS gaskets, the notch will not compress the gasket locally, so there will be almost a bump in the head gasket right there at its thinnest point right next to the cylinder wall.
I've seen slow coolant leaks that acted like cracked heads or cracked blocks from this issue. One time I saw water come pouring out between the head and block while filling the radiator.
The felpro permatorque is a mls, but it has a relief cut out of the gasket at the notch, so it seems to seal ok. There are certain MLS gaskets that you can use, but you have to do your homework to see if they are relieved where that notch is. The graphite gaskets are soft enough to compress so they seal fine.
oP, if the notch is welded and milled properly, yes it will work. If you are looking for .053 or .041, then you can use fel pro permatorque MLS gaskets without having to work the heads. That's what I'm using. Copper coat the **** out of it like BA said
I got my 853's to seal with a stadard GM MLS and the trusty Indian Head Shelack. This is with 800+whp. No leak issues whatsoever
https://ls1tech.com/forums/forced-in...l#post18984264
