Catch Can or LS6 Valley Cover?
Old Jan 28, 2012 | 09:22 AM
BrdOPry's Avatar
Default Catch Can or LS6 Valley Cover?
Well as most people are doing their winter builds right now, I guess I am considered in that group. I'm sick of the oil consumption and am really tor between an LS6 PCV setup and a catch can setup. So if you have any idea to which is more effective other than both thrown together, then post up!
Old Jan 28, 2012 | 10:49 AM
RARON455's Avatar
The ls6 system is a much improved system over the LS1,, however it is nowhere near as effective as a good catch can setup. You will be much better off swapping to a catch can, it works better, and can be bought for the same amount as a used LS6 valley. Not to mention it is alot faster and easier to install than swapping valleys.
Old Jan 28, 2012 | 10:56 AM
BrntWS6's Avatar
Yeah, I was going to get an LS6 valley cover untill I read how many people were still getting blow-by with them. Rx performance CC seems to be the best one out there as it actually has a check valve built into it.
Old Jan 28, 2012 | 01:48 PM
02fbody35th's Avatar
I run the ls6 valley cover in addition to a catch can. works great
Old Jan 28, 2012 | 01:56 PM
1nasty86's Avatar
Turd Gen Guy
yeap, i run both also.
Old Jan 28, 2012 | 02:02 PM
99Bluz28's Avatar
Get the CC, going with the LS6 valley cover turned out to just be an appearance modification for me. I've got the RX CC and it works great, but I'd still think the Saikou Michi, LS1 Dual, CC is another very good option worth taking a look at, and it is made in the USA.
Old Jan 28, 2012 | 04:17 PM
gMAG's Avatar
I've got both.
There is no evidence of oil in the intake, and hardly even a film in the catch can. Nor has the oil level gone down.
Old Jan 28, 2012 | 04:39 PM
Blk98Vert's Avatar
Unless you are burning oil like no tomorrow dont change it. Mine burned 1/4 of a quart in 3000 miles after I replumbed the entire PCV and put in a truck PCV valve, so Im just going to do the catch cans to keep that little bit of oil out.
