cam swap clicking noise ...video
ok i did a tr224 cam swap on my ls1 well everything was well but this clicking noise did not go away what is it any help would be nice im also looking for a turbo also supercharger something in that nature sorry about my face i was using my laptop
http://www.youtube.com/watch?v=YutPcbC2ghc
Sounds like an exhaust leak. Could be leaking where your y hooks up. I've confused a leak there for valvetrain noise right after I did my trunions. Right after you work on something it seems like noises are more noticeable. Make sure the plugs and wires are all tight.
Op: Let the car run for a few min. Look under the car for water by all the exhaust clamps. My car sounded like yours. I found a clamp leaking from the header to the ory. It was dripping on the floor in my garage. Hope this helps!
Also make sure you torqued the header bolts to spec. Think it's 18 lb/ft.
maybe check the swipe pattern on the valve stem for proper push rod length.how many miles on the rocker arms ?maybe you need a trunnion bearing upgrade .I hear stock GM exhaust gaskets seal the best.
