Bearing upgrade? Harland Sharp, Comp, or other?
i used the Comp kit and have had 0 issues. the comp kit early on had some issues with the bolts they supplied not being the right length, but have since fixed the problem. They are virtually the same, but i believe that the HS kit has washers then the snap rings outside the bearing where as comp just has the snap rings with no washers. I dont see the washers having any advantage over just running the snap rings. Hope this helps
dude honestly if your going to be doing that, i would just get a set of scorpion rockers, they're really affordable and make an additional 15-20 hp, not bad for the money
