New AFR 210 LSX heads
#81
Na dude its HP atw, but the superflow that is used to dyno it with is notoriously stingy by 30 HP, regardless im not hung up on dyno numbers im more interested in how it performs, ill post the dyno graph shortly, left the print out at the shop due to the rush on to get it ready
#83
#84
Hi Bud,
Good results for your Ute. I'm the same as you dyno numbers are a guide only and a good dyno is a great tuning aid and then finish off with some road tests. Good luck on Sunday and your times will tell you where you are at.
I'm p----d off I will not be there as have blown a head gasket after the racing down at Lawrence. Would loved to have been there as we could have done a couple of side by side 11sec passes. Let us know how you get on. Cheers Dave.
#85
Hi Bud,
Matt
#86
Aw **** Dave, was looking forward to peeling back a few fords with you, next time for sure, will be interesting to see how it goes down the 1/4 will take a bit of getting used to id say, peddling it off the line will be the trickiest id imagine, anyways let me know if your gonna come up and run a few of the meets over winter and ill come down and we'll make a few passes side by side, would be great fun, regards,
Matt
Matt
3rd orange light comes up). Yeh manuals are a bit harder to get off the line than auto's but you will get used to it. Most important thing is to have fun.
Will let you know when I will be next racing.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#87
First couple of passes get used to the VHT. Depending on the day it will be either very sticky if hot or sometimes gets very slippery if cold. When they have the drivers meeting go to the Xmas tree instructions for first time racers. That will explain when to go off the line. (Always go as soon as the
Will let you know when I will be next racing.![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#88
#89
was a fantastic meet Dave, weather was ace and heaps of great guys there, fastest i managed to dial in was a 12.2 at 114mph, i was struggling to get off the line for most of it either blowing the tires off or bogging it down, once got the tire press. sorted it was hooking great until i smoked the clutch on what would have been the quickest run of the day with the best r/t ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
anyways not too worried as i have that carbon twin plate sitting here ready to go in, im hanging to get back out again though, how you getting on with repairs?
#90
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#91
You will be happy with that Matt for a first time on the strip. Yeh tyre pressures are pretty critical on the track. Once you get the grips of the new clutch & track you will be in the 11's easy. Pulled all the plugs out and #4 pot was full of water. All the compressions on the rest of the cylinders are excellent so looks like a blown head gasket between water jacket and cylinder. Will keep in touch and let you know the outcome. ![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#92
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
