installing lifters...
Old Mar 12, 2012 | 09:55 PM
indigows6's Avatar
Default installing lifters...
I am to the point in my heads and cam install where its time to put the new lifters in. I noticed there is a hole in the side of the body and when i put the lifter in the lifter tray the hole can either be up or down once installed. Do these holes need to be uniform up or down? Or does it even matter? Sorry this is my first time.
Old Mar 12, 2012 | 10:11 PM
crazyelf's Avatar
Are they ls2 lifter trays? If so the notch on one side your talking about goes towards the center(towards the intake). The ls2 block is slightly different and needs the clearance in that spot.
Old Mar 13, 2012 | 01:04 AM
indigows6's Avatar
Its an ls1 block with ls1 trays and ls7 lifters. Sorry im a bit tired. The holes are actually on the side of the lifters after i looked at them again.
Old Mar 13, 2012 | 01:21 AM
wildcamaro's Avatar
When I did my install I just put the lifters in, no special orientation...don't over think it! Good luck
Old Mar 13, 2012 | 09:18 AM
RonSSNova's Avatar
The lifter body is recessed around that oil hole so it doesn't matter what the orientation is.
Ron
Old Mar 13, 2012 | 09:27 AM
indigows6's Avatar
Yea im sure i am overthinking it. Haha I just dont want to have to take this all back apart. Thanks for the replies guys!
Old Mar 13, 2012 | 10:06 AM
outkast6991's Avatar
Notches in the trays should be down on a gen 3 block. As said above oiling holes in the lifter make no difference
Old Mar 13, 2012 | 11:31 AM
RonSSNova's Avatar
I'm wishing I were a seatbelt.......
Old Mar 13, 2012 | 03:55 PM
baxsom's Avatar
so let me get this straight. post 2 says the notch goes up and post 7 says the notch goes down?
Old Mar 13, 2012 | 05:13 PM
crazyelf's Avatar
I was mistaken in my first post, But I really dont think it will matter either way.
