Welding Combustion chamber on 317 head
My buddy has a set of 317s he is willing to give me for my vette. I know the combustion chamber is big so I have heard you can have the combustion chamber welded, then massaged to get the CC down to 59-61cc for a NA application.
Have you done this, and when done proffessionally is there any draw backs?
I was thinking about going this route because a set of 243s or 799 is going to cost me $400 before porting, and to have the 317's welded and machine is $200.
Any suggestions? AI would be doing the work.
I highly doubt AI will do that kind of work for only $150. I have researched their work and they are on the high side for labor.
If your budget is under $2k there are a lot of better options than this welding idea.
Yes the 243/799 is proven, however when you look into it, your going to have $1400-1600 in a quality ported set, when a set of as cast Trick flows are around $1,800.
So the question is, what is better, an as cast TFS or a set of fully worked over 243s.
I went this route because it made sense from a quality and value standpoint. I think the AI work is outstanding, they really know thier stuff. I bought an LQ9 with 30K on the odometer, and pulled the 317s off it. The rest of the LQ9 is being used for a turbo 370 build with rectangular port heads, for my '56 buick. I have 2 other cars which I have dropped over 6 figures into. I didn't do this because I coudn't afford better heads, but the welded 317's, from AI, I feel are as good a product as about anything else available at any price, considering my intended use(NA in a street/strip car with no spray). From ones I've looked at only a Mamofied AFR, or a Mast rectangular port small bore head were viable options. I have heard from 2 tuners, during my own research before buying, that they have seen better performance from the factory ported AI heads than pretty much all of the aftermarket castings, as cast. Only the worked aftermarket castings, like TEA ported TFS, mamofied AFR's, etc are outperforming the AI heads. Is there any negative feedback on any of the AI heads anywhere? There may be but I havn't seen it.
Other reasons to use these heads include, the powdered metal guides, I prefer them to bronze. The stock LS rocker is a great light strong design, upgrade the trunion, and they are awsome IMO. I would not want to swap them out for some heavy aftermarket piece, some aftermarket heads don't work well with the stock rockers. The stealth factor also appeals to me. Who is afraid of an Fbody with 317 heads on it? Its not like having TFS, AFR or Mast staring at you upon opening the hood. I've even thought about having one of those names milled off a set I have. They are nice for a grudge car.
This is a topic that will have many opinions, and I'm sure there are some that will disagree with me. Just giving you my 2 cents worth.
I don't intend to talk you out of the TEA TFS, they are top notch as well, I'm sure you will be happy. My point is that you probably would have been happy either way. The worst thing about AI is getting you heads back, they are in high demand, it is a quite a wait.
If Phil tells you that this is a viable option. Just do it. Ai does great work and has top notch customer service.
I have the lt1 200 cc heads on my camaro. I plan on having them do some ls1 castings for my ls motor.
jmo.
Kory
I am welding on My combustion chambers to add a little quench area opposite the factory flat quench area with the idea being that I should gain a little in efficiency/power as the fuel/air will be forced toward the center in part replicating the GDI concept ,,,,,,aluminum welds easy except that My aluminum wire keeps bunching just past the drive roll ,,,,,,,,,I'm running .030" al wire and I've modified the cable liner so it is about .015" away from the drive roll/bearing and it still bunches up about every 20-30 seconds of welding so I'm getting it done but slowly . I have checked the deck surfaces when cool and there has been no warpage . 1 time I repaired a neighbors 4 cyl cracked head by first removing valves and seals ......etc then putting it on the portable gas grill 4 30 or 40 min then welding , let cool and was burned in awesomely and was'nt any more warped than it already was ,,,,,,,,needed milled anyway .
