243s on a LY6 shortblock
thanks,
Also you will see if many other post, DURATION and not so much lift is the problem with PTV.
I'm 99% certain all the LY6 option engines have Ls3 heads.
I believe it is a mistake to swap them for the 243's, but thats your call.
As far as milling them down for compression, yes you can cut them SUBSTANTIALLY, but you will most likely need to flycut for PtoV clearance. I believe that it is worth the hassle to flycut, in order to be able to cut enough to get compression where you want it.
Barrett
