Ms3 & ms4 users need your input
Where ppl said u have to change your valvesprings every 10 k miles is bus true? I'm getting upgraded springs as suggested but do I have to change them
That often. I plan on daily driving it and I have a good tuner to get the street manners under control and the car has longtubes and basic bolt ons with 200 squeeze thanks for your input
I drove mine daily and only raced occasionally. I think the harder you are on the motor the shorter the life of the springs.
Car is nice to drive the chop sounds great, the street manners are good its a beast above 4000rpm. Like he said, change the gears and get a good tune.
The MS3 has a wider split which will work good with the "man sauce", and it'll be easier on the valvetrain.
I believe TSP says a 3600 is the smallest you want to go.
N/A: 3800-4400
N20:3600-3800
From what I've read
Good advice.
I had an MS3 in a 383 with a 3600 stall and 3.42's, LS6 heads and a 102. It was real lazy down low. It made decent top end power and would suck down N2O like a drunken sailor on leave. Car ran mid 10's on a stock 10 bolt and built 60e for several years.
