Swap cam without pulling damper?
as requested...dont need to remove crank pulley, well only the first time you do the whole install..future cam installs will be a cake walk though.
http://www.quicktimeperformance.com/Cover/index.php
It takes about 5 minutes to pull the damper. No excuse not to. Honestly, if this is your logic (to cut every corner) when modding, you should just leave your junk stock. Will save you a lot of time and aggravation in the end.
As 01ssreda4 said takes about 5 mins to get balancer of plus easier to get to the bolts underneath the balancer then too, i took mine of in about 5 mins, mine was on an engine stand but easier, looked at split covers, any one used them and can you get ones that clear an oil pump and double chain? seen the comp cam ones too clear double rollers and pumps but i don't have the sensor on the front cover.
