Whats so special About LS2 chain?
It's heavier duty compared to the LS1 chain. When I swapped in the new cam on my GTO, I had the shop install a LS2 chain. When they removed my old chain, I compared the two and the LS2 chain was way beefier. I think everything 2005 and later used the "LS2" chain.
Not my pic, but the LS1 chain is on the left compared to the LS2 chain on the right.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
According to my engine builder, all the stock chains have more slack than the aftermarket. They were designed this way as the computers that assemble the motors wouldn't be able to do so if they were tighter.
It seems like there is slack, but it's just enough to keep chain from flying apart during engine running...I thought the same thing bc I took my ls1 chain out during cam swap and was like "I'm glad I'm changing chain bc it's loose." then I put on ls2 chain and it had the same amount of slack...like I said just enough to put the right tension during operation...
Oh yea the guy with lq9 I believe you can use tensioner you will just have to drill and tap into the block, I know some have provisions and others you have to measure very precisely, but in my eyes the reward doesnt justify the risk! I know I ain't drilling a block unless I absolutely NEED to!
Good luck man...ls2 chain is budget perfection lol
1 Post
Just a thought... After seeing how loose a new LS2 chain was, Im glad I installed a double roller. If your putting all your $$$ into building a motor why not spend another $50-60 extra and have the security of a double roller.
I dont want to start bitching fests here, common sense is a double is definitely stronger.
