Pro-Comp Head Studs sold on Ebay
My H11's were roughly $300 more than the ARP's, and thats at cost not retail.
However in a engine not running as high cylinder pressures as a diesel (18 to 1 plus 70 psi in my case). I truly believe a properly installed stud is just that. All you are doing is extending your torque onto a smaller surface area to get a better clamp. Once again as long as they are installed properly. I'm also a stickler as to how many threads I have above my nut on a stud also, so call me crazy.
Bay bridge is all Chinese steel. Oh no! Just like a fast intake is better than a typhoon. Just like everybody needs konis. It's all propaganda. Hell I have an extra set of the eBay studs. How can we test their strength. I'll put em to the test. Someone let me know!
Chinese steel will take a 8.5 earthquake. An 8.5 would put more torque on that bridge than any of our cars with arp bolts. My .02
85 ft. lbs. isn't always 85 ft. lbs.. What kind of lube are you using? how long are/ is the object your exerting force on? think of putting a piece of pipe on a ratchet, 150 lb.s of body weight on a 10" ratchet is a bunch, now put it on a 10 ft. piece of pipe, it's going to do a lot more, think leverage. Hence why a stud is better than a bolt. You have less area you are applying a force to as opposed to the entire length of a bolt your actually stretching. Amazingly lube has alot to do with how much torque is required. ARP lube, 30 wgt. oil, or antiseize?
Rod bolts are properly done by stretch not torque for this exact reason. torque really is a bad way to measure things as there are a ton of variables that come into play. Whereas stretch you have one variable.
Not being a dick or a smartass, please don't take it that way. but if 85 ft lbs. is 85 ft lbs. then it wouldn't matter if you had a bolt or a stud its still 85 ft. lb.
Opinion time:
I HATE the argument that you get what you pay for. That would imply that when I paid top dollar, for a top of the line item, from a top of the line vendor, whos selling this top of the line manufactures, top of the line product..... That would then mean that I got what I paid for: The BEST and that I would then reap the benefits / intangibles that come with buying the best
I have pissed away thousands of dollars on buying the best and being disappointed. I have also pissed away money trying to be cheap. I have been very pleased with some top of the line high dollar items, and I have also been pleasantly surprised by some budget items.
The messed up part about a thread like this is that the "get what you pay for" birds flock in just hoping to see one case of a real failure. Then that usually winds up being a my friends buddy blah blah blah deal. The guys who have actual experience with the item and say they are pleased with it get drowned out and basically ignored
Some one should start a "Who didnt get what you paid for thread". You would have hundreds of inputs and they would be first hand not my buddies blah blah crap.
My opinion on the studs themselves: We are talking head studs not rod bolts. They need to clamp the heads to the block and maintain that through multiple heat cycles. One poster said he has been running them for three years. It sounds like they should atleast be considered a budget alternative to the arps.
jason
