Pro-Comp Head Studs sold on Ebay
Old May 23, 2012 | 08:46 PM
  #101
badazz81z28's Avatar
Originally Posted by KCS
Like I said already...
...if your application truly requires studs, you shouldn't have a problem investing the money for a high quality fastener such as ARP/A1/etc. If you don't have the money for ARP studs, chances are you don't need them in which case ARP head bolts are a more budget friendly alternative to the stock TTY bolts, while still offering the high quality that ARP delivers.
Pro Comp, however, is notorious for having issues with material composition as well as machining QC in some of their other products, such as cylinder heads. Gambling the health of the engine to save about $50 is a foolish choice.
I don't know...I have heard good things about their heads. I really don't honestly think Pro-comp makes any of their stuff anyways. Its all re-branded stuff like Summit or JEGs house brands.
I have a Pro-comp aluminum waterpump on my 350 and works just fine.
As for "needing" studs...I didnt need them, but they are easier on the threads of the block.
I would use the pro-comp studs if it was between bolts, but your right, high hp/boost. I would just stick with tried and proven ARP
Old Jul 14, 2012 | 04:06 AM
  #102
bluchev's Avatar
Im gonna run the China studs, if they fail ill post up.
I wouldn't hold your breath, they look pretty stout.
Old Jul 14, 2012 | 11:22 PM
  #103
Grr's Avatar
Grr
I run em too, no issues and they were really nice quality
Old Jul 15, 2012 | 11:26 AM
  #104
1994z's Avatar
got three set on motors. one set been on it for 3 years with 175 nitrous no problems. other sets one year n/a. no problems.. ls3-ls1-lq9
Old Jul 15, 2012 | 12:02 PM
  #105
RezinTexas's Avatar
i ended up going with arp studs, but only because I found them for $260 on ebay with free shipping.
Old Jul 15, 2012 | 12:37 PM
  #106
I went with ARP studs too ONLY because like above, EBAY brand new for $200!
Although I think some people are ignorant when it comes to off shore products. Don't diss them, until you have used them.
Believe it or not, other people can and DO make good products.
Old Jul 15, 2012 | 02:52 PM
  #107
WheelsUp84z's Avatar
On another note, ProComp added some info on their site about these studs....
"Dont forgot to get a set of head studs if you are going to be replacing or upgrading your cylinder head package, made from aircraft quality 8740 high tensile strength chromemoly steel, withstanding up to 190,000psi. the kit comes complete with 12 point hex nuts and washers."
Sounds like they might be worth a shot for the price.
Old Oct 23, 2012 | 06:17 PM
  #108
LS88FoxBody's Avatar
Well I bought the Ebay Studs , and broke one while torquing. Pretty pissed off.
Old Oct 23, 2012 | 06:28 PM
  #109
Not surprised at all. Sorry man. Hit up their customer service dept., and post here your results.
Old Oct 23, 2012 | 08:06 PM
  #110
S10xGN's Avatar
Wrench type? Torque value? Lube?
Old Oct 23, 2012 | 08:40 PM
  #111
Craftsman , 30 , ARP .
I ordered them off my phone. Didn't realize they were not ARP till I got them .
Old Oct 23, 2012 | 09:52 PM
  #112
BKsNHRA's Avatar
I put mine in a couple of weeks ago. Used arp moly lube. Spent a lot of time cleaning the threads. Had no problems at all.
Old Oct 23, 2012 | 10:10 PM
  #113
Silver Sleeper's Avatar
i didnt want to spend the $$ on the ARP studs so i just went with ARP head bolts in my turbo LS....i used the chinese head studs on my old turbo 302 and popped a HG after two highway pulls, re torqued them and two nuts stripped on the stud..
Old Oct 23, 2012 | 10:31 PM
  #114
RedRocketZ28's Avatar
I just got my car running a couple of weeks ago. Haven't had any problems with my studs and have hit 9+ lbs. Hoping they do alright when the car is fully tuned and the boost is turned up.
Old Oct 24, 2012 | 09:10 PM
  #115
S10xGN's Avatar
30#? Come on, a grade 5 hardware store stud wouldn't strip at 30#...
Old Oct 24, 2012 | 10:22 PM
  #116
DGageSS's Avatar
My thought too. I have these studs on my 408. Work fine so far. Torque to 85.
Old Oct 24, 2012 | 10:42 PM
  #117
1nasty86's Avatar
Turd Gen Guy
my "theory" is if you buy cheap ****... dont complain when it messes up... from the ws6 store the ls1 studs are 269.99 with free shipping.. i mean come on guys
Old Oct 24, 2012 | 10:43 PM
  #118
1999BlueTA's Avatar
^^^Lol wow just caught that, I agree, I will be running these in my H/C/I build so I'll see how they work out, they look like pretty stout pieces, imo!!!
Old Oct 27, 2012 | 04:17 PM
  #119
hiltsy855's Avatar
I found this interesting - There is a head stud set on eBay here that has these torque specs in the listing:
11-mm bolts torque is 52lbs
6-mm bolts torque is 19lbs
Bolt torque lube must be used
They aren't the ProComp studs but the torque spec is pretty low, at least compared to ARP which is 70 / 80 & 22. I'd be interested in seeing the torque spec for the ProComp studs. Also interested why LS88FoxBody torqued the 6mm bolts to 30 ft-lbs (I assume it was the small stud that broke).
Old Oct 27, 2012 | 05:52 PM
  #120
BKsNHRA's Avatar
Mine came with no torq specs. I messages the seller. He said stock specs. I dident really agree with this. So I had a pack of moly lube from a previous install on a stang. So I used the arp moly lube and specs. Had no trouble. My car is n/a. Haven't sprayed it yet. But if I have any trouble ill let y'all know. So far so good
