Pulling heads with studs?
Old Apr 14, 2012 | 02:34 PM
mypoorLS1's Avatar
Default Pulling heads with studs?
Do the studs need to come out, or will the heads fit over them. Car is a 98 Fbody
Old Apr 14, 2012 | 02:56 PM
bww3588's Avatar
tight squeeze but it can be done. Just as easy to unscrew the studs just like bolts IMO.
Old Apr 14, 2012 | 02:58 PM
Darkman's Avatar
https://ls1tech.com/forums/generatio...ads-studs.html
https://ls1tech.com/forums/generatio...heads-car.html
Old Apr 14, 2012 | 03:26 PM
tillery's Avatar
Ive done it a few times on my 2000 f body. You have enough room to do it. Without pulling the studs out.
Old Apr 14, 2012 | 03:38 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
On the passenger side, you have to leave them in, specifically the bottom ones in the back since there isn't enough room to remove them with the head on the block.
Old Apr 14, 2012 | 04:05 PM
mypoorLS1's Avatar
Thanks guys. Just wanted to know what I was in for. I'm about to start the job. A few guys asked about that. I thought there was room. I'll take my thread chaser with me just in case
Old Apr 14, 2012 | 04:34 PM
01ssreda4's Avatar
Taken mine off several times. None have to come out of the block. Anyone who tells you otherwise doesn't know what the hell they are doing
Old Apr 15, 2012 | 03:17 PM
Schantin's Avatar
As stated, the heads can come off with the studs still in the block. Done it before .... no issues
