Arp head bolts vs arp head studs
Sorry to jack your thread but I have a question reguarding this. Next spring I plan to instal new crank, rod bearings, along with a fresh hone and new rings. All on the stock bottom end. I am doing this because I need to reseal the oil pan, and plan to instal a heads/cam combo as well. I was going to do head studs. Should I do crank and rods too? Or just reuse factory on those?
Rod bolts are one thing because the oem ones are weak as ****, but do you even hear about people breaking mains in street applications?
#34
#1 reason why I decided to go Studs. I would be just so sick to death if I twisted out a head thread on a brand new block . Head bolts have been used by many without any ill effects, but I want a higher percentage of success.
#35
#36
#40
I know that this is an old thread. But I thought I should address this because it seems to be such a commonly believed misconception that studs should NEVER be used unless the head can be pulled clear from them. This is simply UNTRUE. Studs are no more an obstacle than bolts in a crowded engine bay, and may actually make things EASIER in some cases. What is often neglected is the fact that studs (like ARP) have Allen sockets on the top, and can be removed before the heads. They can then be reinstalled after the heads are placed on the block. This way, you need not worry about whether or not the head can clear the studs when it needs to be removed. Furthermore, without any bolt heads to worry about, studs can easily be removed even in situations where a bolt head would interfere with something like a brake booster when pulling the bolt out of the hole. Yes, there is the extra step of pulling the studs after loosening the nuts and installing them before tightening the nuts. But this is certainly no deal killer when it comes to using studs. Especially when you look at all the advantages of using studs vs bolts.
