HELP! middle of cam install i need help
Old Mar 27, 2004 | 01:14 PM
2001zz's Avatar
Default HELP! middle of cam install i need help
O.K. I am installing my t-rex cam package and new ls6 intake. I thought since i had the intake off i could just remove the lifters like this and save me some money. Took the intake of and saw i guess was the valley cover loosend teh bolts on it and i am getting ready to remove the coolant lines. My quesiton is do i need a new gasket for the valley cover i am going to remove it to try to get to the lifters.
also there was a lot of crud under my intake that i have to clean up, i dont know where it came from. thanks
oh yeah btw i hate removing these intakes what a pain. thanks
Old Mar 27, 2004 | 01:26 PM
99 Black Bird T/A's Avatar
The only way you'll get to the lifters is to pull the heads. LS1 isn't like the SBC where you can get to the lifters via the intake/valley cover.
Old Mar 27, 2004 | 01:28 PM
2001zz's Avatar
yep just figured that out lol. pos.
so will i need a new gasket for the valley cover? what do i torque them back down to? thanks for the help
Old Mar 27, 2004 | 01:32 PM
I like to use new gaskets for stuff like that. Depending on what condition the gasket is in you might get by. I don't have the torque spec for that handy. Sorry.
Old Mar 27, 2004 | 01:35 PM
http://www.ls1howto.com
check on JMX's site. It should be in the torque spec's somewhere.
Lot's of good info on how to do a cam swap on that site too.
Old Mar 27, 2004 | 01:40 PM
2001zz's Avatar
****. where can i get a new gasket? i really wanted to get thsi put togehter this weekend. maybe i can get away with this one. what if i put some gasket maker on the old gasket?
Old Mar 27, 2004 | 01:48 PM
What condition is the old gasket in?
Old Mar 27, 2004 | 01:49 PM
foff667's Avatar
LS1TECH Sponsor
it took 12 minutes for someone to respond to this thread...you couldnt wait 12 minutes for a response? lol
Old Mar 27, 2004 | 01:50 PM
Might call AutoZone, Advance Auto, Napa etc and check if they have one. Any of the dealerships in your area have the parts department open on Sat afternoon?
Old Mar 27, 2004 | 01:53 PM
2001zz's Avatar
foff667
i already loosened the bolts before i posted.
i havend remove the cover completly just pried up on the edge of the front and say no lifters.
Old Mar 27, 2004 | 02:20 PM
2001zz's Avatar
also all my valve seals are the same color. i thought the intake and exhaust were diff.
