no oil pressure
Old Apr 28, 2012 | 11:06 AM
StripedSS's Avatar
Default no oil pressure
Not getting any oil pressure. Filter filled up, took it off, then started it again, oil shot out, took valve cover off, n no oil up there. What seems to be my problem?
Old Apr 28, 2012 | 01:13 PM
King Nothing's Avatar
were you gettin oil pressure before? what was it? were you doing anything when your oil pressure dropped? how many miles on the engine? mods?
Old Apr 28, 2012 | 03:19 PM
StripedSS's Avatar
Put a ms3 cam just ported n polished tha heads new valve seats dual valve springs ported oil pump from texas speed ls7 lifters thunder racing 7.4 chromoly pushrods dual timing chain new main and crank bearings. Had normal oil pressure always just above 40 at idle when stock... engine is at 115000. This was first start up after swap. So no oil pressure on new parts. Did three 5 second runs n nothing. I would shut it off to prevent further damage to engine if any.
Old Apr 28, 2012 | 03:21 PM
StripedSS's Avatar
And a new oil pressure sensor, back cover n rear main seal.
Old Apr 28, 2012 | 04:45 PM
bigpat501's Avatar
either you didn't get the pick up tube oring in right or it just hasn't had time to get up top yet i would pull the plugs disconnect the coil packs and pull the injector fuses and crank on it for a while and see if it primes
Old Apr 28, 2012 | 05:19 PM
yep! pressurize it first before you try to run it. something i never knew about until this last week. who installed everything and did they mic the bearings and verify everything was within tolerance????? if they put the bearings in wrong you can block the oil passage holes and you'll get no oil pressure . . . better hope it's not that cause the engine will come right back out and apart again not too much work but takes time to check things if you want it to last
Old Apr 28, 2012 | 05:40 PM
StripedSS's Avatar
Thanks guys im gonna try tha priming then take it apart again. Aaaaahhhhhhhhhh tha time is a killet! But thanks again guys!
Old Apr 28, 2012 | 06:03 PM
No prob let us know how it goes!!!!
Old Apr 30, 2012 | 01:12 AM
Chevyboi09's Avatar
Sry I'm kinda havin the same problem right now with the whole no oil pressure thing but idk how to start a new thread on my phone. But I think I threw a rod and was wondering if that could be a reason I'm not getting any oil pressure. If someone can get back with me on this I'd appreciate it. Thanks
