LS6 Intake with TFS 215 heads?
I just got a good deal on a set of TFS 215's but would have to save up for a FAST 90 or 92 so I'm debating just sticking with the LS6. How much would an LS6 intake be holding me back with TFS 215 heads?
Also on a side note, why are FAST 90-92 going for as much or more than FAST 102's?
It is going to hurt you a bit, but since you can't do much about it you'll be fine. I would suggest a 102 with those heads as they are a better design and will yield more HP. Exspecially since the 102's are cheaper, people think the 90/92's are gold because they no longer make them. In my .02 they should be around $500-600 but that's just me. People say you spend a lot more going to a 102 because of the different used parts. Fact is you can budget shop, example:
New 102: $800 shipped
ls2/3 rails: got mine for $30 off eBay, normally $100 ish
Ls2 injectors: $100 or so, or buy a rail adaptor for your stock ones: $50-70
It equals to about the same amount and you have a better intake with a better design, in turn yielding more HP
I wouldnt worry about it. The ls6 is a great intake and there is always going to be something thats better and makes alittle more power.
If you look hard you can still find deals on 90/92's. I'd suggest a 92mm TB for either intake so it doesn't hit the water pump like the 102 TB usually does. I gained 19rwhp with my FAST 92 on 2.5 LS6 heads. I'd say you'd gain a good 25 possibly as much as 30rwhp with your setup.
But yeah, you also have to factor in the cost of a FTP lid, bigger MAF, bellows and touch up tune when going to a FAST setup.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
A lot, easily 20 considering Ive seen several gains of that on stock ported head/cam cars that ran an LS6. And to answer your question they are retailing for that high because 90% of the LS world is naive when it comes to intake manifolds and have no understanding of how they work. When my source has them available I can get a 90 for $500, which is what they are worth
The best way to see just how much power it will cost you sticking with the ls6 intake is to bolt the heads on, run them and see how much vacuum you are pulling at full throttle...if you are pulling a lot of vacuum then the FAST will show a big difference, if you are pulling little or no vacuum at full throttle then the ls6 intake is all you need and you would be wasting your money on the FAST.
Or, you could just box the new 215's up and give them to me...that way you won't spent any more money putting them on your car...just think of the money in bolts and gaskets alone I would save you
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I thought a new FAST 92 was expensive then I saw one for sale that had body filler on it sanded and painted black with the direct port nitrous ran inside the intake they wanted like 1800 for that, sick looking intake looks like a ls6, but way too much.
Well the heads were supposed to just need a cleanup but really needed to be milled about .015" which would make the chamber too small for me to use so I'm going with AI ported 243's. From what I've seen in the dyno section they make similar power.
If I stick with the LS6 intake, should I swap the TB or would the intake be the restriction?
http://advancedinduction.com/LSX/AiLSx230ccTFSHead.php
