tie bar lifter install??? and pushrod length??
Old May 30, 2012 | 08:46 AM
ausls1's Avatar
Default tie bar lifter install??? and pushrod length??
Just recently installed my howards tie bar lifters and bolted the heads down, my question is after someone asked me if they were installed in the right way is which is the right way?
I know might sound like a dumb question.
I put them in with the oil gallery holes in the lifter facing the oil passages in the block. The link bars are facing away from the valley plate area, so towards the exhaust side off the heads, does this sound correct? or should the link bars be facing the valley plate area?
2nd question is i carried out my pushrod length check on my newly built ls1 stroker motor and have 7.26" reading with zero lash 9-1/4 turns off my checker gauge (similar to comp gauge tool), then get 7.32" with zero lash on 10.5 gauge turns and 1-3/4 to 2 turns till torqued and 7.36" with zero lash on 11 gauge turns and 1-1/4 to 1.5 turns till torqued.
going by these i was looking at 7.350" pushrods length, does this sound right or am i off a bit with my calculations?
I also did a rotation with a mark on the center off the valve tip and was basically in the middle off my factory rocker i'll be using with the 7.32" length, not sure if that helps a bit.
Thanks in advance and sorry if any off this has been covered a million times.
Old May 30, 2012 | 09:31 AM
mark21742's Avatar
In my opinion 2 turns to torque is way too tight....I'd look at 7.30" pushrods....try to get it to 1/2-1 turn to torque max if you shooting for around a .040-.050" preload
Old May 30, 2012 | 09:34 AM
ShifterLou's Avatar
I'm going to be doing link bar type lifters as well so I'm subscribing...
Old May 30, 2012 | 04:32 PM
ausls1's Avatar
Yeh with 7.26-7.28" length i was getting bout a 1/2 turn till torque so 7.30" would make sense. Will check again with that length and if thats on 1/2 to 1 turn whem torqued will get them.
That would also bring me smack on middle off rocker tip as well, will double check that again tonight.
Old May 31, 2012 | 05:56 AM
ausls1's Avatar
ordered the 7.30" pushrods, rechecked and spoke to a couple of places who said the 7.30" would be be the go for same reasons you mentioned mark21742.
Also was told that as long as the tie bars aren't fouling then should be ok, iv turned it a number off times and couldn't hear any unusual noises or feel anything locking up, but will double check, if anyone else has any more input this would be good.
Old May 31, 2012 | 06:31 AM
mark21742's Avatar
I'm spinning ls7 style comp lifters to 8,000 rpms now, so when my heads come off again I think I'll end up going to link bar lifters along with a good adjustable rocker set up....lol I just find it hard to drop another $2,000+ in the valve train...even though in the back of my head I know I need to
Old May 31, 2012 | 07:21 AM
ausls1's Avatar
yeh fare enough, i did extra to my heads cause of my stroker motor, which i'm hopeing to drop in the car this weekend if my new stall convertor turns up tomorrow.
Hopefully start it on sunday and run the cam in then try and get it towed to the tuners with out an exhaust (going to get them to weld the cat pipes in the correct spot) a week or so later to get a base tune to run it in and work out what i need to tweak and with fuel system, gauges, etc in the meantime, just small things anyway, got 99% sorted, well at least i think anyway.
Old May 31, 2012 | 07:43 AM
ShifterLou's Avatar
I'm currently having that battle in my own mind.
Not the shaft rockers though.....yet.
Old May 31, 2012 | 08:45 AM
mark21742's Avatar
When I do it I think I'll get the Morel link bars and Jesel adjustables....buy big, buy once lol
Old May 31, 2012 | 08:49 AM
ausls1's Avatar
Im using factory rockers with the comp trunion upgrade, see how they go, got howard cams lifters that are meant to be morells, or like morells.
Old May 31, 2012 | 09:07 AM
mark21742's Avatar
Oh, no, font take me wrong, I have nothing against Howard cams or their parts....actually I like and have run some of their stuff
Old May 31, 2012 | 07:30 PM
therabidweasel's Avatar
With the comp linkbars, the bars go toward the valley.
Old May 31, 2012 | 08:31 PM
ausls1's Avatar
Oh ok, yeh iv got mine with the bar on the outside facing away from the valley, might have to change them around then.
