Need suggestions on what cam to replace T1
Old Mar 4, 2003 | 07:26 PM
Speed Demon's Avatar
Default Need suggestions on what cam to replace T1
My cam and lifters have to decided to eat each other. The surface of the lobes and rollers has started to break up.
What cam should I get to replace/upgrade the T1?
I have heads that are milled 0.038.
Old Mar 4, 2003 | 09:02 PM
Cal's Avatar
Cal
Default Re: Need suggestions on what cam to replace T1
I say get a C1 Hammer cam to replace it. Or if you want to go bigger, a TR224. BTW, why did your T1 self-destruct?
Old Mar 4, 2003 | 09:06 PM
I was also thinking the TR224.
I don't know why it self destructed.
Old Mar 4, 2003 | 09:35 PM
Cal's Avatar
Cal
Did you lube it real good when you installed it?
Old Mar 5, 2003 | 09:04 AM
I installed it 40,000 miles ago. Yes, it was lubed well at install.
Old Mar 5, 2003 | 09:20 AM
CHRISPY's Avatar
hmm strange that isnt good <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Depends on a couple of things. You have emissions testing there? A need for good driveability? What springs are you running?
Cheers,
Chris
Old Mar 5, 2003 | 11:11 AM
gator's 99TA's Avatar
i say a 228/224 type cam if you want to buz the motor up there. if not go with a 224 comp xe-r. pretty smooth and lots of power. i run a 230/230 and it rocks! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 5, 2003 | 11:25 AM
ChrisARE360,
No emissions testing for me. I was running MMS springs. 150lbs. seat and 360lbs. open.
gator's 99TA,
I have to be sure that I won't have any piston to valve clearance problems. The 228/224 sounds good but probably would have clearance issues.
I was thinking about the comp 224 .563 112 or maybe a 226/224 .563 112.
