help with 5.3 into a s10 build
Old 06-20-2012, 01:00 AM
beeker82's Avatar
Default help with 5.3 into a s10 build
Im picking up a 5.3 from a friend this weekend,and as soon as I move into my house next month Im looking for a s10 to swap it into. This wont be my DD,and will be a street/strip/car show cruiser. 12.99 in the 1/4 would be my first goals. Whats a basic direction to go with the 5.3 to start off? Port the 5.3 heads,ls6 intake, etc etc? Whats a good size cam and stall to go with?
Old 06-20-2012, 03:46 AM
widopn's Avatar
When I had a 5.3 in my S10 with just a cam and bolt ons it ran middle 12s on a slower than usual track. It was an LM7 5.3 with a TR224 cam, swap headers, 4000 stall, and a 3:73 gear. It ran 12.52....
Old 06-20-2012, 05:14 AM
mark21742's Avatar
Like above, I'd say a 224 or a 228 and great stall like a Yank or Vig should get you there end the ported heads will help out even more.
Old 06-20-2012, 11:24 AM
milktasd's Avatar
Port and mil the stockers or get some 243s port and mil(to get compression back up), ls6 intake, longtubes if you can afford it, under drive pulley. I'm towards the end of my swap. 2000 Sonoma 5.3 with 243s, ls6, UD, 4.10s, t56, longtubes, etc.
Old 06-21-2012, 12:16 AM
beeker82's Avatar
Some awesome info in this thread. Is there a huge power and driveability difference between the tr224 and 228r cams?
Old 06-21-2012, 02:08 AM
mark21742's Avatar
In a 5.7 the 228 is on the larger side of the mild cams, so in a 5.3 it would be more aggressive, but with a good tune still very street friendly
Old 06-21-2012, 06:12 AM
milktasd's Avatar
I had eps spec me a cam and he recommend me his tt2 218/226 .595 .598. Told him drivability>power>lope.
Old 07-01-2012, 12:44 PM
99 WS-sick's Avatar
iv got a set of 317 heads that i milled .020, installed comp .620 lift beehive valve springs, mildly ported an polished, an did a 3 angle valve job. they have never been ran, let me know if your interest.
