ptv with stock cam??
So, I thought, ok this cam is way too big and was gonna get it reground to a 228/228 but then I installed the old stock cam and it did the same thing, piston stop...what am I doing wrong??
5.3 stock shortblock with arp rod bolts
853 ported heads, .030" had them cc to make sure
Stock rockers
Stock length pushrods
Did use solid lifters
Cam is in dot to dot
Please help, I need this thing running!
I installed head with gasket on, used a stock pushrod length, with #1 cyl on tdc I snugged rocker bolts, then used the eo/ic to put lifter on cam base circle and snugged bolt once again to find 0 lash, did same thing with exhaust valve. Am I doing this right? If so, I can put everything back together tonight and have her running by weekend!
