Swapping 806 heads for stock 243s?
Old Jul 1, 2012 | 11:26 AM
slvr T/A's Avatar
Default Swapping 806 heads for stock 243s?
My mods are currently full exhaust, BBK SSI intake, LID, underdrive pulley, 228r cam, and a dyno tune. I put down 390/375. My buddy has a 6.0 out of a TBSS just sitting around and I noticed it has the 243 heads. He said I could HAVE THEM!! But I don't have the money to go get them worked so I would just be transferring the stock 243s onto my engine. My question is would there be a good enough gain to do the swap or should I just wait and buy some CNC heads later down the road to make better power? I've searched on here and haven't really seen anyone go from shitty 806s to stock 243s.
Thanks in advance.
Old Jul 1, 2012 | 02:23 PM
Darkman's Avatar
https://ls1tech.com/forums/generatio...806-heads.html
Old Jul 1, 2012 | 04:13 PM
slvr T/A's Avatar
ah I see. Need to work on my searching skills.
What do you drive Darkman? I'm in Spring too.
Old Jul 1, 2012 | 04:41 PM
Burken01's Avatar
get them, then sell them for $550 and put that into your car.
or get a clean up mill for $60 and put them on and run them..
Old Jul 1, 2012 | 04:45 PM
slvr T/A's Avatar
haha that's what I was thinking. But if I take 'em i'll get them milled a little and run them. People are saying a stock set of 243s going from 806s usually gain 20+rwhp.
Old Jul 1, 2012 | 05:09 PM
Darkman's Avatar
2005 Cadillac CTS-V, LS6 TFS 215s, FAST 102, cammed and tuned by PatrickG.
Old Jul 1, 2012 | 05:29 PM
slvr T/A's Avatar
dayyuummmmmm!! That's sick i've probably seen it around before.
SStressin's Avatar
deffinatly ditch those heads they are junk.. atleast put some stuck 243s on them
Old Jul 1, 2012 | 05:48 PM
slvr T/A's Avatar
yeah i'm pretty sure those heads will help out a lot. i'll get them milled .020 and probably do a valve job. he's got the valve covers and coil brackets to go with them too!!
Old Jul 2, 2012 | 10:04 PM
Burken01's Avatar
yes dude, your about to come up.... most people pay $700 for a setup like that..
Old Jul 2, 2012 | 10:43 PM
TransAmWS.6's Avatar
Stock unported 243's are probably good for 10-20rwhp I would say, however they are an upgrade from the 806's and will definitely show decent gains once you port them
Old Jul 4, 2012 | 02:23 PM
MonmouthCtyLS7's Avatar
You'll see around 15 hp, I would save for atleast a valve job.
Old Jul 4, 2012 | 02:49 PM
wooddaniel's Avatar
Also remember that you will need new valve covers for the 243s. I say go for it they will be an improvement for sure and at a bargain. I bought a used set off here for 400$ almost brand new only 2K miles on them
Old Jul 5, 2012 | 04:36 PM
2000RATA's Avatar
The 806's with $500 in porting would murder the 243's. I port heads for a living and the 806's in ported form are as good as any 241 or 853 ported. Anyone that tells you different is ignorant.
Old Jul 5, 2012 | 07:49 PM
gMAG's Avatar
I must agree. And, you can keep your valvecovers.
Mine are self-ported. In 4th, between 4 & 6 K, this engine roars, with plenty in reserve.
It's a little scary, actually!
Old Jul 5, 2012 | 08:44 PM
garygnu's Avatar
I think you should get the heads.you can check the valve seats for leaks your self by pouring solvent down the port runners while they face up.if they don't leak you can install them with some new springs.
Old Jul 11, 2012 | 07:13 PM
slvr T/A's Avatar
Well i've decided to get some work done to the heads. at least getting a valve job and having them milled a little. May send them to AI.
