228r and torquer v2 rpm range
Old Jul 21, 2012 | 07:54 PM
chevybayboy's Avatar
Default 228r and torquer v2 rpm range
Does anyone know the rpm range on both did see it on tsp website
Old Jul 21, 2012 | 08:05 PM
simplysix's Avatar
Part of it will depend on lsa, I'll let tsp answer the rest
Old Jul 21, 2012 | 08:10 PM
duweller's Avatar
If you search dyno after XXX cam. It should provide decent amount of dyno graphs with results showing power range.
Old Jul 21, 2012 | 08:28 PM
Thanks got it
Old Jul 21, 2012 | 08:30 PM
duweller's Avatar
I actually searched this not too long ago for the 228r cam it looked to me like it droped off around 62-6300rpms with a 112lsa+2
Old Jul 21, 2012 | 08:49 PM
Ok I like the torquer v2 lsa112 whats the plus for at the end I never go that
Old Jul 21, 2012 | 09:16 PM
JUSTINSWS6's Avatar
+4 is 4 degrees advanced, +1 would be only 1 degree advanced or 3 degrees retarded from +4. Retarding cam timing results in all valve events happening later.... advancing the cam results in valve events sooner. the most influential valve event is intake closing, by retarding cam timing the intake closes later and since duration does not change cylinder pressure will bleed off as the piston comes upward with intake valvestill open, result is less cylinderpressure = less torque at low rpm.
Justin
Old Jul 21, 2012 | 09:21 PM
99Bluz28's Avatar
With running the same LSA and ICL the TRQ v.2 will have roughly 150-200rpm higher power band
A 112lsa+2 = 112lsa with a 110icl
Old Jul 21, 2012 | 10:46 PM
Dang thanks guys that info helped me alot I also wonder what that was for.. Cant wait im thinking either toruer v2 lsa 112+2 or 228 same lsa
Old Jul 22, 2012 | 12:03 AM
Sladester2's Avatar
228r better for street imo.
Old Jul 22, 2012 | 12:21 AM
I wanna be able to get rhem on the freeway as well, where you get the lights for your hood I waa doing the same for my camaro
Old Jul 22, 2012 | 12:30 AM
99Bluz28's Avatar
Consider the trq v.2 with a 111lsa to move the power band down slightly, but with still better power then the 228.
Old Jul 22, 2012 | 12:42 AM
Ok its sounds nice on YouTube as nice choppy idle
Old Jul 22, 2012 | 06:31 AM
PREDATOR-Z's Avatar
Justin
Theoretically yes, but does it really happen that way?
Old Jul 22, 2012 | 11:57 AM
Sladester2's Avatar
I got the lights from autozone. Just some LED's. Wired them to my battery and to a switch located in my ash tray since I dont smoke :p
Old Jul 22, 2012 | 01:22 PM
Nice.. I was going to do the same thing lol,looks good tho
