Rocker tightening sequence for adjustables?
Senior Member
What is the sequence for doing adjustable rockers? I dont want to have to turn the motor over 100 times to get all the rockers adjusted.
I made a remote starter switch for mine to use for rocker adjustment. I ran wire to the small term. on the starter solenoid, and a wire to the 12v(+) on the driver side. Using a push button you'll be able to 'bump' your way through a lot easier.
Senior Member
The motor is out of the car right now. I just didnt want to spin it over a bunch of times to get all 8 done. I was wondering if anyone knew the valve sequence like the SBCs for adjusting the rockers.
Thanks guys
Thanks guys
