EDIT: FINALY GOT IT! (stripped my fuc****crank threads all the way) installing pulley
#82
Take the 16 X 2.0 adapter & go to the hardware store & get a piece of all thread that fits in the end of the adapter & a nut & you have a install tool.
Use the bearing in the install kit & it will go right on,no heat required.
I put mine on & it went on like butter.
#83
^^^^this
I bought a piece of allthread 16x2.0 mm, a couple nuts and a bunch of washers. Screw the allthread in by hand, install washers and nut, and it should slide right on.
I welded a nut on the end to be able to use a wrench to screw it in the crank, but didn't need it. Worked great. Good luck
#84
Was in same exact position about a year and a half ago. I tapped the snout of the crankshaft and it was much easier then I though it would be. Took me about 30-45 mins. It has never once come loose or caused any problems in since I installed it 20k miles ago
#85
#1... you are going to screw it up more if you get it red hot
#2.... it doesnt just slide on by hand when you do heat it up.....its an old school trick to get a stubborn crank pulley started...but it still has to be pulled on with a tool...
#3.... with the luck you are not having... please go get some all thread or order some from http://www.mcmaster.com/#standard-threaded-rods/=iyunnl
the part you want is 99055A140 and cut it down to what you need...
you can get a 300mm piece.. but its smarter to get something longer and just cut it down
you can get washers and nuts from here too by the way...
#86
!!!!!!!!!!!!!!!!!!!!!!FINALLY GOT IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
used the autozone tool and it went on EASY this time. I installed the damn thing with a 3/8 ratchet! Didn't even have to use heat lol. I'm so damn releaved this thing is finished. My torque wrench only went goes to 150 ftlbs. So I torqued it there and than got one more good turn on it. So I would think I am pretty damn close to 200ft lbs. (My machinest told me to not torque on the helicoil threads over 200ft lbs) Than I took bolt out torqued new bolt to 37ft lbs and went an aditional 120 degrees. Put belt on and turned it around everything lines up and spins dead perfect.
#88
#2. Wrong. The last 3 times i have installed my crank pulley I have heated the hub and the crank pulley slides on easy a **** and deadheads on the crank. You have to slide it on quick, the crank pulls heat out of the pulley extremely fast. I have never ever ever ever ever had a front seal problem doing this. Is it wrong to do? not for me, ill do it every time i put on my pulley.
#90
...every last single thread is stripped and almost no threads left.
If anything, it's likely he bottomed the long bolt out completely and kept turning.
#91
Before assuming the OP is The World's Leading Expert on crank thread depth, consider the part where he said:
So if he didn't thread it in far enough, how did the threads get balled all the way in?
