Need the pros help again, Valvetrain noise
Imo you should not be getting on something that has issues at idle. It sounds like something is up electrically or on the top end, but I am no expert. Did you verify the wipe pattern? What are your lifters and what did you set for preload?
It sounds like two discrete noise sources. Valvetrain is likely one of them, the other almost sounds like a big exhaust leak.
Did you ever get an accurate lifter preload measurement?
Also from the response to my thread, looks like those patriot dual springs are garbage!!!
https://ls1tech.com/forums/generatio...-breakage.html
