Rod Bolts
Old Sep 4, 2012 | 03:24 PM
bww3588's Avatar
Care to prove that?
Care to explain how after installing stronger bolts, many people including myself had big ends go up to .003 o-O-r?
Old Sep 4, 2012 | 04:03 PM
imma_stocker's Avatar
Originally Posted by bww3588
Care to prove that?
Not to be a dick but who are you talking to? What do you want proven?
Old Sep 4, 2012 | 04:06 PM
bww3588's Avatar
That cracked caps will not move...obviously they do move or you wouldn't have out of round issues.
Old Sep 4, 2012 | 05:14 PM
Never said they wouldn't move or go OOR, just that they are designed to fit back together exactly like the factory sends them out. Rod #1 must have rod end #1 bolted back to it in the right direction. Grab 2 cookies and break them both in half. Then put them back together. Same thing with factory cracked rods. Read this. and this
The crack method used at the factory to separate the rod from the end creates a unique pattern on both sides of the break. So they'll match back together one way and only one way. Damage caused by anything else is just that, damage.
I don't see how changing bolts would affect it either. They are separate pieces and rod bolts are just fasteners. Fasteners shouldn't mess with what they are fastening unless the parts are warped or torque is off.
Old Sep 4, 2012 | 05:24 PM
bww3588's Avatar
It's not that simple. Just because it is a cracked cap design, does not mean it has no room to shift in any direction.
Different fasteners with different clamp loads, tensile strength...etc will move the caps, regardless of design. Caps don't just go out of round for the hell of it, obviously movement on the parting line is the only thing that can cause that.
Old Sep 4, 2012 | 07:05 PM
chrisfrost's Avatar
In My experience getting the rod caps back to the exact same way as before removed is fairly easy as long as You don't have any foreign material and You don't ding any part of the rod or cap and You use You're eyes to inspect them before and after . If You don't have natural mechanics and physics aptitude and decent eyes I would not mess with it ,,,,,but if You do and You're careful You should have no issues .
Old Sep 4, 2012 | 07:48 PM
bww3588's Avatar
So your saying a calibrated eye is enough to see if your rod cap is shifted .001 from where it was to begin with?
Ok...
Old Sep 4, 2012 | 08:19 PM
redbird555's Avatar
Originally Posted by 1bigoldman
I do not understand this.
What difference would it make if using ARP vs. stock or katech? On a basic level a grade 8 bolt is a grade 8 bolt, right?or whatever grade is used for rod bolts. We are not talking about torquing to yield so there should not be any measurable amount of stretch. The torque spec is the same isn't it? If you warped the bore wouldn't they be over torqued? So why would the rods need to be resized to change to higher quality bolts??
Yea sure if we are doing a textbook rebuild yes we SHOULD resize the rods. He is wanting to only change the bolts.
Please elaborate with some facts.
Thanks
The fact is that that would be true if all bolts had the same "clamping force" if you will and tensile strength. Also you should not the arp torque specs are different than the standard gm bolts and the bolts also yield a higher clamping force. Therefore they have the potential to warp the bore and cause a failure. The katechs are not prone to stretch like the stockers are but still have the same "clamp force" therefore they will maintain the bore shape. As for how they maintain the clamp force of stock bolt but ont stretch I dont know as thats katechs secret but they do work.
There is no failures from using katech bolts while there are many failures shortly after installing arps. Now there are people who use arps without issue but is that chance worth the $100 price difference between katechs and arps? To me its not...
Old Sep 4, 2012 | 08:31 PM
KCS's Avatar
KCS
Moderator
First of all, I was talking about the bearing itself, not the caps.
That's what I'm talking about too.
Old Sep 4, 2012 | 09:10 PM
ZQ8LS1's Avatar
I rebuilt my L33 with cracked capped rods & used ARP rod bolts & no resizing...5,000 + miles later its still running strong & I doubt I will have any problems if its gone this long.
The caps can only go one way. I was a amazed at the cracks/breaks on some of my rods.
Old Sep 4, 2012 | 09:12 PM
GST's Avatar
GST
Originally Posted by Paul Bell
GST, welcome to LS1tech! SEARCH will be your best friend around here.
After purchasing this low oil pressure motor, what did you plan to do with it?
Thanks for the welcome.
My plan is to put it in my sons 67 Camaro. It will be all stock at this point and a summer daily driver. I'm hoping to give it a good once over and run it. We'll get the combo instaIled and decide where to go from there. I was going to change the oil pump and check the old one to (hopefully) find the failure.
Old Sep 4, 2012 | 09:19 PM
  #32
GST's Avatar
GST
Originally Posted by chrisfrost
If this engine had an oil pressure issue and You have the engine not in any vehicle , now is the time to check all the bearings and/or replace them ,,,,,,chances are there are a bad 1 or 2 in any of the locations .
Not a bad idea
It's on my engine stand so I can easily check all of the bearings.
Greg
Old Sep 4, 2012 | 09:25 PM
  #33
GST's Avatar
GST
Just noticed the pics in your sig. Nice Monte
I had a 1970 SS454 Monte Carlo. It wasn't 600 hp (only 500) but it was still like using a sledge hammer to install trim.
Greg
Old Sep 5, 2012 | 06:16 AM
  #34
Paul Bell's Avatar
That's MISTER MODERATOR
Cool! What colors?
About your engine, I suggest while you have it on the stand, you do go through it. New rings, bearings, oil pump, gaskets, perhaps have the heads gone through and a cam/springs kit. Remember some fasteners are TTY and the head bolt holes need to the empty & dry.
Old Sep 5, 2012 | 08:58 AM
  #35
chrisfrost's Avatar
Bww , in My experience thus developing My opinion the stronger bolts cause out of round big ends by way of squishing the caps a little more but the parting lines because of the cracked cap design stay the same on 2 of the 3 dimensions ,,,,,,,with respect to the engine block side to side and front to back . The purpose of the honing is to bring the big ends to round again .
I fabricated some tools to hone My rods so I spent alot of time studying closely the parting lines and I can say in all honesty I can see a .001-.002" difference because I'm comparing the rod to the cap when They are together . Take a drill bit then find 1 that is a cpl thous bigger or smaller and compare side by side ,,,,,,,,,You should be able to "easily" see the difference ,,,,,,,,,
Old Sep 5, 2012 | 01:09 PM
  #36
Ah I think I see what you're getting at. Rod manufacturing has little to do with what happens to the rod, cap, and bearing. They all work the same but can take more "abuse" depending on how its made, what its made of, shape, weight, etc. So the rods being cracked has nothing to do with how it went OOR. Sure the cracks "should" help the cap and rod section stay in place but real life happens so they won't necessarily.
Gotta keep in mind though that improper torque, wrong torque down pattern, fasteners of much harder metal, fasteners of much softer metal, bearing clearances, and crank wobble can all throw it OOR. Some take forever and others don't, depends on what happened inside the motor when it was running.
Hell, I bought a motor with 6 of 8 rods bent with a slight S bend (don't hit nitrous without any jets ). It was enough to knock like hell and go very slightly OOR but the bearings looked fine to the naked eye. The rods looked fine until a close look too.
OP: you're on the right track. While the engine is on a stand you might as well go through the whole thing. Car will be killer when you're done with it. Throw some disc brakes and decent suspension on for a panty dropping resto-mod!
Old Sep 6, 2012 | 12:26 AM
  #37
GST's Avatar
GST
Cool! What colors?
I painted mine Ice Blue Metallic. No vinyl top. Very cool car.
I plan on checking all of the rod and main bearings and depending on what I find I will do rings, bearings etc.
I'm definitely doing oil pump and gaskets.
At this point I'm hoping to keep it low budget.
I have a feeling that once I get into it I'll know how far I'll have to go
Old Sep 6, 2012 | 05:21 AM
  #38
john563's Avatar
Originally Posted by garygnu
you can change the rod bolts while leaving the rod and piston in the block.just do 1 rod bolt at a time.get some kaltech rod bolts ,these seem to be the only rod bolt that dose not cause any out of round with the big end of the connecting rod.these are cracked rods and it seems that removing a rod cap is not a good idea.
this is^ I whent this route with katechs one rod bolt at a time..that was bout 4-5 years ago..H/C/I nitrous..i use clevite bearings p series
