Ls6 head (head bolts?)
Need to know what gasket I should order and I guess ARP head bolts?
If someone could provide me a link where I could order these I would greatly appreciate it.
About to dig around on summit and Texas speed and see what I come up with.
http://texas-speed.com/p-784-arp-hex...04-blocks.aspx
It's hard to beat the GM MLS head gaskets. Get the LS1 gaskets if you have a LS1 or LS6 block.
http://texas-speed.com/p-209-gm-ls1-...d-gaskets.aspx
Unless you plan on taking the heads off in the future I wouldn't waste money on arp bolts, the GM ones are still good quality for what you are doing...the only thing the arp bolts do is make it easier to torque the rear head bolts under the coal rather than "stretching" the GM bolts. I used GM bolts and unless I was turbo/supercharging it I would spend the money for the arp...
Figured I'd tell you my experience...good luck bro (those 243s do make a nice difference!)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
