Lifter issue - please help
Old Sep 12, 2012 | 02:21 AM
kunkelz28's Avatar
Default Lifter issue - please help
I got done with my H/C/I swap (a few hundred miles since the swap) and i am having a lifter tick, (it gets loud not normal valvetrain noise) driver side on the back maybe 5 or 7. what really stumps me is the tick comes and goes it seams to be worse when the motor is warm, what can i do without taking off the head?
any help would be greatly appreciated
mods
1999 Camaro SS - 6 speed
PRC 215 heads
fast 92 mm intake
92 mm throttle body
tsunami cam, 235/240 648/605 111
42 lbs injectors
racetronix fuel pump
new plugs/wires
longtube headers
off road y pipe
borla cat back
double roller ls2 timing chain
new water pump
new alternator
tuned by Hi Tech Motorsports
Old Sep 12, 2012 | 04:24 AM
therabidweasel's Avatar
I don't see hardened pushrods, what lifters you're running, or a trunion or rocker upgrade in your list.
I had a tick like that with my YTs that was way high on the motor. I think it was slight interference with the valve cover, fixed by removing and reinstalling the cover and rockers for head torque.
Old Sep 12, 2012 | 07:07 AM
garygnu's Avatar
I would think as the motor heats up and the head and block expands ,the distance between the rocker and the lifters grows resulting in less preload.maybe try a little longer push rod.
Old Sep 12, 2012 | 12:55 PM
Gary is right, you lose about .008 in preload. But if you're using ls7 lifters that is nothing...unless you didn't measure well and were marginal to begin with.
Old Sep 12, 2012 | 01:43 PM
KevinR's Avatar
I don't know, man... I had the EXACT same problem when I did my cam swap. It wouldn't make any noise on a cold start, but after a few minutes of warming up, it would start to tick. It ended up being a lifter on #7.
Old Sep 12, 2012 | 03:03 PM
Slick68's Avatar
I'm having a similar issue. I've got alot of valvetrain "clatter". Looks like I need to invest in a pushrod length checker. I also used stock lifters and rockers. I really hope I don't have to change lifters. That means another set of bolts and gaskets.
Old Sep 12, 2012 | 09:27 PM
kunkelz28's Avatar
sorry, to add to my mods
ls7 lifters (they were soaked for 36 hours)
hardened PR
Its really weird that its only in one or two cylinders and it comes and goes
Old Sep 12, 2012 | 09:55 PM
cranny's Avatar
What kind of oil are you running? You could try switching brands or maybe a straight 30 weight to see if that helps.
Old Sep 12, 2012 | 10:09 PM
kunkelz28's Avatar
royal purple... right now i was gonna switch to mobile 1 5w30 to see if that helps, any other ideas?
Old Sep 14, 2012 | 01:43 AM
kunkelz28's Avatar
any ideas?
Old Sep 14, 2012 | 02:48 AM
Burken01's Avatar
did you reuse your lifter tray's? or buy upgraded ls2 tray's...?? coulda twisted a lifter slightly if you used old trays
