Help me pick an oil pump
Old Oct 10, 2012 | 10:37 AM
moespeeds's Avatar
Default Help me pick an oil pump
Swapping out the heads on my LS1 to LS6. The car is a roadcourse only track car, will spend all it's running life at high RPM. Changing to an LS2 timing chain, what should I do for the oil pump? I've been offered a great deal on a new LS6 pump, but what about the Melling HV pumps, and what model would I need? Sorry I'm pretty ignorant to this whole thing, so any help is appreciated.
TIA
Old Oct 10, 2012 | 10:45 AM
mark21742's Avatar
I'm running and would recomend the 10296 melling high pressure/ volume pump.
Are you still running stock pan or aftermarket? If you could herbal slightly larger pan to hold some more oil your motor will thank you
Old Oct 10, 2012 | 11:09 AM
ace32x's Avatar
ported ls6 oil pump, cant beat it for the price
Old Oct 10, 2012 | 12:01 PM
wildcamaro's Avatar
Yea I would go with a stock ls6 pump, the high volume one will suck your pan dry unless you have one bigger than stock...
Old Oct 10, 2012 | 01:02 PM
venom99's Avatar
if your road racing i would go to a dry sump set up
Old Oct 10, 2012 | 02:17 PM
Undertow74's Avatar
i got my ported/coated pump from SDPC, damn good price too
Old Oct 10, 2012 | 04:50 PM
mark21742's Avatar
This is the best answer, but very expensive....but well worth the investment.
Old Oct 10, 2012 | 04:59 PM
jrane's Avatar
The high volume melling Part # (10296) will suck your pan dry if your going to be running on a road course especially if your using a stock oil pan. If I was you I would run just the high pressure melling part # (10295) it won't suck your pan dry especially if you are pulling high lateral G's, and is only $100.
Old Oct 10, 2012 | 05:17 PM
fatmat80's Avatar
like mentioned before..dry sump for the turns..ported ls6 for the straights for my money!!
Old Oct 10, 2012 | 06:39 PM
mark21742's Avatar
Not saying it hasn't happened, but I've never had a problem sucking my pan dry
Old Oct 11, 2012 | 05:56 AM
chrisfrost's Avatar
A little off topic but real close ,,,,,,,,,,,,,for road racing where You're engine is going to be spending a large portion of the time in the 3000-4000 rpm range if You don't have a timing chain damper You need 1 or plan on breaking chains ,,,,,,,the harmonics in that rpm range kills chains without a damper quickly .
Old Oct 12, 2012 | 03:09 AM
ls1 1990 VN's Avatar
If money is an issue for dry sump, use an 'Accusump' works for me.
And yes for a timing chain Damper or fit an ATI pulley, I broke a dual Rollmaster using a 25% ud Powerbond.
Oil pump, use high pressure 'but not' high volume.
LS6 or Mellings
Old Oct 12, 2012 | 08:16 AM
Bramlok's Avatar
Everyone in my group of friends with LS motors are all running the Melling 10295.
Old Oct 12, 2012 | 10:20 AM
gMAG's Avatar
Melling 10295 works just fine.
You can even port it yourself. It a 'piece of cake'.
Old Oct 13, 2012 | 01:37 AM
01ssreda4's Avatar
Old Oct 14, 2012 | 01:57 PM
1bad03snake's Avatar
I'm rebuilding a lq4/t76 for a weekend toy. I have a ls6 oil pump and a melling 10296 what pump should I go with? This is a street car with mostly weekend use and no twisty's.
Old Oct 16, 2012 | 04:24 AM
Either, both are great pumps
Old May 8, 2013 | 01:53 PM
Sleeper S10's Avatar
those with the Mellng 10295... what's your oil pressure like?
what's normal?
Old May 8, 2013 | 02:14 PM
03Sssnake's Avatar
In addition to any oil pump, if its going to be dedicated auto-x/road race car. I would add a road race baffle to the stock oil pan, an accusump setup, oil cooler and remote oil filter setup as well.
baffle for LS1 pan
