stock cam with prc .650 springs?
So I just bought a huron speed turbo kit and I needa get some money for it so I'm thinking about selling my 224r and putting stock cam in. I have read that you need better springs with boost so I thought about just selling the cam and keeping the springs in... So my question is. How long should these springs last with stock cam??? I would think they could go a long time with stock cam considering they are made to use with high duration/lift cams...
I'd sell them and pick up a set of ls6 springs and cam. The ls6 cam will give you more potential under boost than a stock ls1 cam.
If you are going back to the stock cam but also going with an FI setup I would check in the FI section to see what the recommended spring forces are and work from there. I don't think the time they last is the question, it is how much spring do you need to control the valves under boost.
