LS1 RIP? Lifter stuck in bore....
My original issue was no compression in that cylinder, a nasty tick, low oil pressure & oil in that cylinder.
I'm assuming the intake valve was slighty open = no compression, the tick is obviously the lifter & cam not happy with each other anymore, low oil pressure is probably the lifter letting the oil pressure out??? but whats up with the oil in that cylinder? btw it all happened at the sametime.
My main question is, how do i get the lifter out without causing more damage, I haven't removed the cam yet either.
Let's say i get it out and the lifter bore is galled or scuffed up etc. is this LS1 block done? or can I get the lifter bore lined or an insert be put in?
I would get a estimate to see what would be the best cost effective solution.
Pretty sure they will have to disassemble the shortblock to bore the lifter bore.
Good luck.
Yeah i do all my own work, I'm working on a new engine build so not sure if i'll even waste my time/money with the LS1
the biggest issue i've got now is making the decision...... I truely thought it was something more major (bottom end damage) than what it was so i'm already trying to put together a stout race engine (AES 390ci, 6.0L block, LS3 stuff, E85 conversion & Vortech YSI) but as well all know that just doesn't happen overnight. so i'm lost on what to do.
Option 1 - pull the LS1, fix just the lifter bore issue and put same parts back in but obviously buy new cam & parts to fix it to go back to running 10.40's lets estimate at $500 or more
Option 2 - pull the LS1, tear it apart to fix the lifter bore issue and while i've got it all apart put a good 346 bottom end in it and go that route & put more N20 to it and have fun for a few more years but that estimate of $3000 that i'd put towards my next bullet, not to mention the weak none machinable cylinders.......
Option 3 - pull the LS1, bag it & put away, continue with the 390 idea & sell off parts of my LS1 (heads, intake etc) to help generate extra $ to help the new bullet & YSI idea... estimate = big money lol
I agree, I can't imagine putting the same stuff back in or buying a bunch of stuff and not know if its good enough, option 3 you would know it would be the best route.
That is the other thing i forgot to mention, I'm doing an LS swap into a 54 Ford (long story) this winter so no matter what I wont be doing any engine stuff to the Vette, so racing is out for next year
but I can save all year long this way so I hope 2014 season...... watch out
