Sleeper approach mod list- 02 Ws6
Goal? 95% stock looking/sounding/etc car capable of running bottom 7s @ 100+. I want it so even if an educated LsX owner looked the car over, they would find little to nothing to make them suspicious the car is modded more than a lid.
Here is my plan so far:
AI worked 241s
Stealth cam... It will have zero lope and retain stock RPM idle. Something like high 21X/ low 22X .58X 114 I even considered an ls6 cam as I can use the stock springs/etc since this is a strict budget (I'm not crazy about spending a ton on the DD and taking away money from the toy).
Money marker intake- Pilled with either 75 or 100 shot. I will only use it if I absolutely have to to win, if I'm winning it will never be sprayed.
I was considering an underdrive pulley... However, that would stand out to me looking a car over as very few people would install an UD pulley and not have many other things done prior or during that swap. Thoughts?
I am up in the air about the exhaust... It has the SLP dual dual on it so I am set as far as a catback goes. It draws attention just stock and I don't want to to be loud. For some reason even swapping to a LM would make people thing it is faster than it is because it is loud. If I do anything to exhaust it will be pacesetters with a FM merge.
I understand the gains that would be had on a H/C car with full exhaust, and what I would be leaving on the table.
However, I think exhaust would GREATLY take away from the total sleeper effect. I want it to seem stock. If it is still extremely quiet with LTs ORY into the factory SLP DD I would probably do it, but it would have to be BARELY louder.
Chrs1313 ram air... If I did it, I would paint it black so it didn't stand out. Not only do I think most people wouldn't notice it, most people wouldn't care if it was on there, it isn't going to make THAT much of a difference but will show gains. I will pick up a used one for cheap.
Stock gearing will be staying in the car as traction is already hard to come by.
Any input/advice is appreciated. I have never considered a build as such so I might be forgetting some simple things and I want input on the exhaust, etc..
Nobody, nobody, will know what is done to the car. Everyone already thinks I spray it because it is an extremely hard running car and I can drive/shift correctly. It beats things much worse than it "should" and keeps up/is even with things it "should" get pulled by for a car with a lid and shorter stick only.
I am decent at making enough things add up that people aren't going to pin point what is done. So much BS gets thrown around my town, you can beat a car 7 lengths and people hear it was neck and neck.. Neck and neck and it was a slaughter one way or the other. Anybody with some sense to them will know something is done to the car but if they cant find anything they cant prove anything
I really did think about putting the stock lid back on... It doesn't really pick up any noticeable power. But then again, everyone knows a gearhead can't have a true 100% stock car so it would probably make them question it! LOL I think the lid can pass.
Suspension is staying stock unless I upgrade something on the pewter car, then the DD will get the part I took off the pewter car.
1st gear is already useless if I go completely WOT and it doesn't care for the bottom of 2nd either... If it is below 45 degrees, traction is a joke. The stock 3.42s will suffice for this... I also want to keep my MPG as I drive the car daily and often on 150+ mile round trips on the weekend to go out of town.
I don't think many, if anyone, would notice an UD pulley so I'll probably toss one on. It doesn't absolutely mean there has been a cam swap.
Nice idea on the bullet if I do mess with the exhaust, that will help.
Thanks for the suggestions guys, keep them coming.
flowmaster catback
throttle body spacer
underdrive pulley
Hypertech tune
SLP 85mm MAF
cheap shorty headers
"cold air intake" with a 90* bend instead of upgrading the lid and doing ram air
Then they wonder why the car is slow.
Will be keeping up with this thread for sure
flowmaster catback
underdrive pulley
Hypertech tune
SLP 85mm MAF
I'd like for my DD to be able to run with a lot of peoples "fast" car.... That way I can say I'm not even going home to get the Pewter car. LOL
1. Most people don't care what intake setup you have... so all that is fair game.
2. The IM and TB would need to be stock appearing to not raise any suspicions.
3. An UD pulley isn't really a big deal even if seen.
4. Since you already got the SLP dual dual exhaust I would leave that alone.
5. I would go with the SLP Y pipe that connects to the stock manifolds.
6. You've got the right idea with AI ported heads and a stealth cam/quiet valvetrain.
7. Have the heads shaved to give a little bump in compression.
8. Hide the nitrous bottle in the spare tire well.
9. Hide the solenoids under the radiator shroud/air box.
10. Hide the n2o control switches in the center console.
1. Most people don't care what intake setup you have... so all that is fair game. True... But $ wise and even power wise for this build the ls6 will do me just fine
5. I would go with the SLP Y pipe that connects to the stock manifolds. Good thinking on that, it slipped my mind, this may be a very valid option.. I almost talked myself into headers just for the spark plug changes though! LOL I think manifolds will stay though
8. Hide the nitrous bottle in the spare tire well. Can't go there, too common... I have some ideas though!
9. Hide the solenoids under the radiator shroud/air box. I thought about that but again common, I have a perfect place for them, especially with the money maker intake plummed
10. Hide the n2o control switches in the center console.Again, common... I have a perfect spot for them that is easily accessible yet will never be seen.
Thanks for the thoughts, I like the SLP ORY.
Ls6 cam
Ls6 exhaust manifolds
Ls6 intake
241 A.I. Ported/milled heads
Pulley
85mm MAF since you have it, but SD would be better.
Lid
Ported TB
Ls6 cam
Ls6 intake
Pulley
Lid
Ported TB
I hope the fast car on motor car could pull this one even spraying. LOL
