What CAM is this????
Old Apr 12, 2004 | 10:23 PM
Dueledaily's Avatar
Default What CAM is this????
I just got my cam package in today...The cam itself has rust pits on it, and the box it cam it says 13/06/02 on it....like its been siting for a while...
The numbers on the cam are...as they apear on the cam..
1.3:20(and then an upside down U) 11:00B
05902 08002
In between each cylinder intake and exaust setup there is yellow paint. ( 4 spaces with paint total)
Can anyone name this cam? I hope?
Old Apr 12, 2004 | 10:54 PM
Dueledaily's Avatar
Default Also...
i forgot to menchon...there is a blue/burnt color on the sides of the lobes.....
05902 08002
Old Apr 12, 2004 | 11:00 PM
SSEUL8R's Avatar
that blue burnt color on the lobes sounds like someone might have gotten that cam pretty warm, maybe do to poor lubrication.
Sudz's Avatar
a used one
Old Apr 12, 2004 | 11:06 PM
Dueledaily's Avatar
Default its a new cam
Its New...their is no sign of lobe ware.. I know its new!!! I wanted to know if its the right cam i ordered...
Originally Posted by Sudz
a used one
Old Apr 12, 2004 | 11:07 PM
Ferocity02's Avatar
You ordered a cam and it came with rust pits? Send it back regardless!
Old Apr 13, 2004 | 12:00 AM
goober35's Avatar
I would throw a fit if i ordered a cam and it had any sign of uses on it. Send i that thing back and make sure to take pics so they dont try and screw you.
Old Apr 13, 2004 | 12:21 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
The blue color is from the heat treating. You might be able to match it up by the lift numbers, but you would need a dial caliper to first measure the base circle, then measure the difference at the lobe (1/4 turn from base circle measurement) and subtract it. That will be your lobe lift, multiply that by 1.7 and thats your valve lift.
Old Apr 13, 2004 | 06:20 AM
DANSLS1GTO's Avatar
No offense, but why would you order a cam from someplace that you wouldn't trust to send you the right part you ordered?
Dan
Old Apr 13, 2004 | 06:32 AM
99-LS1-SS's Avatar
STF Veteran
Take a pic of it and post it. People can give you a better idea of the condition of the cam. Take close ups of the area's you are curious about.
Old Apr 13, 2004 | 03:30 PM
Dueledaily's Avatar
I ordered the cam from SDPC. The rust on the cam came off after scratching it. But I still can imagin that they would have this cam sitting on shelves long enough to get rust on the camshaft. I though their was a chance they sent me the wrong cam. I ordered the hot cam kit and was trying to see if anyone knew what a hotcam looked like.
Old Apr 13, 2004 | 10:49 PM
35th SS's Avatar
kevin check your mail.
Old Apr 14, 2004 | 11:02 PM
Dueledaily's Avatar
Default your great!!
Thanks for the help man!!!!
