Cam swap/ Stumped please help/update/got her running
#41
Pulled line that goes to fuel rail pumped as much fuel out as possible put new fuel in it ran for like a min backfire and cuts off Idk what the hell the problem is now
#42
Yea it will run for like a min then die out and back fire like crazy if I let off the gas and backfire and die out any other suggestions on what it might be or does it take a really long time to get the fuel out heres what I did
#44
The tune may be why its backfireing. You changed heads and cam.Somecars will run.Not real well but will run on the stock tune and some just dont take it to well untill tuned. A tune may solve all your problems.
#46
It could happen. Im still wondering if the valves hit the pistons when he spun it over with the first problem
#49
Ok I'm going to get a video up.. I pulled a few plugs like 3 where wet I'm going to hook it up to my scan tool I'm think bad o2 sensors it won't backfire until its under 1000 rpm backfire then cut off ill post a vid in 20 mins
#51
[QUOTE=snyousef;16923184]If your plugs are wet with fuel...it could be a sign that you have fuel but no spark. Did you have a chance to check spark?[
I didn't check the spark I was thinking maybe a coil or o2 sensors.. I got video up
#54
#60
could this be the culprit??
so i got under the to down check to make sure all the wires were hooked up and this is what i find
i think this guy has something to do with the misfire and backfire also i keep blowing a 20 amp fuse inside fuse panel number 2 in row 1 i think its my turn signals every time i turn car over it pops any iddeas on that?? anyway i think im going to still just wait until the code reader comes
