Cam swap/ Stumped please help/update/got her running
Old 11-26-2012, 01:29 AM
  #61
chevybayboy's Avatar
Another thing where I messed up I installed my rockers wrong again I torquerd intake then spun the motor and did exaust..... Ugh I need to pay a little more attention to what I'm doing and stop trying to rush to get.her started I will fix tomorrow and see if that's what my problem is
Old 11-26-2012, 08:39 AM
  #62
outkast6991's Avatar
Originally Posted by Martin@Tick
Something is wrong, I just was saying the tune may fix it or not.
Outkast what was your idle rpm set at?
stock idle speed was 800rpm. i'm not saying it idled perfect but it did well enough to be somewhat stable
Old 11-26-2012, 09:17 PM
  #63
joecar's Avatar
Hmmm, what was this supposed to be (besides not being plugged in):
Old 11-26-2012, 10:51 PM
  #64
There were all melted together I pulled a few apart
Old 11-27-2012, 10:57 PM
  #65
Originally Posted by MM98
Yes, I'm running LS7 lifters & my cam is 236 on intake duration using longer 7.425 pushrods.. Are you still using ur old 98 coil harnesses? Make sure the coil leads are in this order.
1. PPL
3. LT BLU
5. BRN
7. DK GRN
2. RED
4. DK GRN/WHT
6. BRN/WHT
8. LT BLU/WHT
Didn't get it til now!!! I checked my coil harness and my wires on it was backwards I switched around and in the morning I will give it another shot thanks dude
Old 11-28-2012, 08:12 AM
  #66
Sales@Tick's Avatar
Well that is the problem! If your wires were switched around backwards that will defintiely cause it to backfire!
Old 11-28-2012, 08:41 AM
  #67
87caprice318's Avatar
Did you ever try it out again?
Old 11-28-2012, 09:23 AM
  #68
Lol I know it clicked when I was eating A bowl of cereal stop eating to go check and driver side was backwards thanks for sticking around and with all the help again
Old 11-28-2012, 09:24 AM
  #69
I'm going to try it wen I get home in a few hours
Old 11-28-2012, 07:00 PM
  #70
Finally got her running after the few days and thanks to mm98 that was the issue with the backfire ans thanks to martin for the right up got my valves adjust right on valve train sounds like it did when it was stock
Dyno coming real soon
Old 11-28-2012, 07:30 PM
  #71
snyousef's Avatar
Nice, glad you figured it out...
Old 11-28-2012, 07:39 PM
  #72
Sales@Tick's Avatar
Good job bro!
I'm glad I could help with the lifter preload and everything else!
Old 11-28-2012, 08:19 PM
  #73
Thanks man let me know when you start your build so I can tag along
Old 11-28-2012, 08:21 PM
  #74
Good job bro!
Thanks again man I'm looking into a n2o setup ill be giving you a call when I'm ready
Old 11-28-2012, 10:49 PM
  #75
MM98's Avatar
Good deal man, glad you got it running.
Old 11-29-2012, 09:04 AM
  #76
zzcamaro00's Avatar
so what did those melted connector end up being?
Old 11-29-2012, 10:00 AM
  #77
Thoses were going to the o2 sensor I just rewired them hooked my scan tool up to it and code was gone and I cleared the other codes from my auto conversion
Old 11-29-2012, 10:32 AM
  #78
Hey man could you please give me that lifter adjust write up???
Old 11-29-2012, 12:47 PM
  #79
Yea ill send it over now
Old 11-29-2012, 12:53 PM
  #80
snyousef's Avatar
I have a thread started already in the carbureted section but I haven't started yet but will be soon
Quick Reply: Cam swap/ Stumped please help/update/got her running
