Engine back from machine shop, some concern...
Besides physical proof showing tdc and the cams degree during revolution, what makes it wrong besides a dot to dot being incorrect? Ive spoken with texas speed and hes speaking with them today as well to see what the issue could be.
Comp Cams has a great article on degreeing cams in. It's not that difficult. If you degree in SBC you can degree in a SBF, or Hemi, or an LSx. It's all the same.
Used to be a time when torque plates were a special "race" sort of treatment but they are standard production use on engines for a long time now, torquing a plate over the bore allows the metal to be distorted as it would be when the head is bolted on.
If you used new pistons and had it bored .005 over with the studs and torque plates, great.
If this guy reused stock pistons no boring and went along with changing from bolts to studs without making you aware it is just more evidence that he should stick to 1970s stuff.
To be clear though this would be a quality of workman ship issue, it wont blowup the engine or anything, the ring seal would just not be as good as it could have been.
I explained why it is not ideal to swap fastener types without remachining, if you have some technical explanation to refute that then by all means enlighten us.
If torquing fasteners didn't affect the block then things like torque plates would not be used and we could use ARP rodbolts without resizing rods etc.
Take a look at an LSx deck tho. 1st look how far away the bolt holes are from the cylinder, 2nd look and see that the holes are seperated from the cylinder wall by a water jacket. Not saying they won't distort, but doesn look like a high probabilty. Because I dont have proof, some research on the net, will confirm alot of people would agree an Aluminum LS block would not be affected by a torque plate. My question is directed back as to prove your supporting evidence.
EDIT: Also keep in mind, the torque is different from using ARP bolts vs OEM TTY....Nobody had reported a problem from my search and TONS have switched over.
It could very well need a tooth skip on the cam gear. If the degree wheel and dial indicator were used properly...it doesn't lie or make assumptions.
GM cams have strange centerlines and wide splits compared to Comp cams.
I will say though if I were using a stock GM LS6 cam however, I would just stick it in dot to dot and call it a day. I wouldn't even have degreed it
As far as the stud kit goes, i called ARP, Texas Speed, a couple of the local machine shops, and a local speed shop, they all said that theres nothing wrong with installing studs and that theyre just hand tightened then the heads are torqued on top. I used a digital ac delco and snap torque wrench to assemble the rest of the engine.
OP is is really starting to look like it will be a big gamble to run this.
