Engine back from machine shop, some concern...
Old Dec 19, 2012 | 07:03 PM
  #41
c6matt's Avatar
Originally Posted by Tony Nichols
It's already been ran..
Originally Posted by nofxrxmxpx
I never browse this site any more... Alas.. Subscribed to see if it fires up!
wow....or read posts anymore
Old Dec 21, 2012 | 08:37 PM
  #42
Black_Widow_SS's Avatar
Some intense reading and learned quite a bit from this. How's that engine holding up?
Old Dec 22, 2012 | 05:38 AM
  #43
RezinTexas's Avatar
haha, this is awesome.
Sorry you had to go through this, that guy has no business building LS motors.
How is it running?
Old Dec 22, 2012 | 08:33 AM
  #44
Tony Nichols's Avatar
Im sorry i had to go through it as well, believe me. It runs perfectly fine. I have it setting on the engine cradle mounts, checked for leaks, noises, issues, everything worked perfectly.
Old Dec 22, 2012 | 02:32 PM
  #45
RezinTexas's Avatar
sounds good, glad it worked out.
I would suggest an oil analysis after 1k miles or so. That will show if you have any problems relating to excessive wear, blowby, small internal coolant leaks, etc.
Old Jan 7, 2013 | 05:57 PM
  #46
Sooooooo, not quite sure, but im pretty sure, this is backwards....Your opinion........................................... ....
Supposed to be a brand new seal that he installed. Looking at everyone elses seals and the install pic from GM, it looks wrong in there and doesnt look fresh either.
Old Jan 7, 2013 | 06:06 PM
  #47
KCS's Avatar
KCS
Moderator
Yeah that doesn't look right. It literally says "this side out" on the side of the seal that faces out!
Old Jan 7, 2013 | 06:30 PM
  #48
I checked the new one from the dealer and I know it says "this side out". I'm pulling it tonight to redo this seal
Old Jan 7, 2013 | 06:33 PM
  #49
RQSGTO's Avatar
Yep....that's backwards!
Old Jan 7, 2013 | 06:43 PM
  #50
100% positive?
Old May 11, 2013 | 10:28 AM
  #51
Been a few months, back on the road with it, breaking it in and getting it "right". I created a set of 180* headers for it, rewired and depinned the harness, and purchased a new pcm and had it recalibrated. Runs very nice now, but one of the resistors broke in the MAF so i resoldered it until the new MAF gets here to dyno it. 500 Miles, second oil change done, 27psi idling hot, 42-55psi ~2-3k.
